Dimastech Bench Table V2 Review
Dimastech have been making bench tables for years, any hardcore overclocker or industry proffesional wants or has one. There's a good reason too, the open top design makes working on or around your motherboard or GPU an absolute doddle. Recently Dimastech have staged a come back with a V2 version of their famous table that was starting to get very hard to get hold of in the UK. Thankfully OC3D have one in the labs for testing so lets move on and take a look at some specifications:
Specifications:
  • Bench made from sheet metal 1,5 mm,
  • CNC laser cutting,
  • Powder or Enamel, basic phosphatic
  •  Totally "Made in Italy"
  • Marked "Made in Italy" on the back of the Bench/Test Table
  • Compatible with ATX and Full ATX motherboard and Micro ATX, XL-ATX, Mini ATX
  • Installation of up to 3 devices 5.25 inches
  • Installation of up to 3 hard drives (3.5 inch) 4 or more floppy disks with no floppy drive,
  • Support for sockets with fan ventilation area 120x120,
  • Support for ventilation area opposite 120x120 video card fan
  • Latest keys wired for power and reset switches, (n ° 2)
  • Holes on the front and back of the motherboard to allow the passage of cables and pipes for watercooling downstairs
  • PSU supports positioned on the front or back of the Bench/Test Table
  • Compatibility with power supplies up to 22cm in length,
  • Lateral support for the installation of all types of radiators on the market (HwLab, Thermochill, TFC, Etc)
  • Rear space for installation of a compact liquid cooling system,
  • Thumb Screws step M3 and 6-32 (American pitch UNC)
  • Support for 120x120 mm fan for cooling systems in SLI/Crossfire
  • Rubber feet
  • Ram fan support 120x120 mm
  • Lower drawer with sliding tracks and fixation with screws knurled side
  • Placement supported devices on slots
  • Personalization side of the body with the basic version of the Bench/Test Table
  • Adjustable positioning device support
  • Supports for adjustable radiator over the back of the Bench/Test Table
  • Screws also knurled nuts
  • Total elimination of the use of instrumentation outside the Bench/Test Table
  • Fully compatible for mounting versions of media and Bench/Test Table Hard V1.0 and V2.0
  • Full compatibility with the new Bench/Test Table Hard V2.5
  • Prepared for 4 passes for watercooling pipes or fittings on the back of the motherboard
  • Possibility assembly front USB port (DimasTech USB Cable is available as an accessory - see section Accessories)
Lets head over the page for our first look.
«Prev 1 2 3 Next»
01-06-2010, 06:24:31
tinytomlogan
Many of you have asked what I have been using in some of my videos, so now its time for you to get a proper look.
Continue ReadingQuote
01-06-2010, 07:59:57
m0o0oeh
Looks like a very nice piece of kit - certainly going to come in handy for OC3D to test new components - you can just keep the board up there, and just chop and change out the bits and bobs you need to test!
Awesome piece of kit there, and a nice review TomQuote
10-06-2010, 06:52:29
LooseNeutral
Yes, glad you got one for "A barrage of motherboards, heatsinks, graphics cards and ram"! Sounds like your going to hit us with a nice barrage of reviews Got a feeling you'll know soon about that PSU bracket after a proper TTL workout. Great review as always.Quote
10-06-2010, 07:49:05
Rastalovich
I have a few bug-bears with these things.
Concept - excellent, great things to have when you constantly work with changing out bits, components, testing. If they're exactly as you require them.
Prices - absolutely rediculous up to this point. Cheapest one I've broken ** was probably £75 or so, and felt like it. I didn't buy it, so hey.
Essentially, an enthusiast can put one of these together themselves, suprisingly cheaply. If you consider yourself a compitent wc'er and especially a case-modder, the task is simple.
** the breaking usually comes cos although the basic form is there - they don't facilitate 'something' - so you end up modding it in some fashion.
LL tray - $25, salvedged parts from old cases, "hack saw", misc cables from your favorite outlet. Coat it ? I've scratched the heck out of them usually with so much in/out of components. Monkey prints on the LL stuff can be annoying tho.
Meh, each to their own.Quote
10-06-2010, 08:23:37
tinytomlogan
I was all for the cheap versions too Rasta, but tbh once you get something quality like this, especially for something that for me at least will get a huge amount of use they are worth twice the retail price. Kustom PC's has these in stock for £109 which is brilliant imho.
My only bugbare was the PSU bracket which i do belive will be getting changed asap, other than that the quality was top notch.Quote
10-06-2010, 10:18:53
FragTek
Spelling error, page 3, "professionals" Quote
