Eddie EK FC79 7800/7900 GPU Block
Test Results and Overclocking
Search Reviews
Page <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 13/08/2006
Author: Matthew Kemp (kempez)
Hardware Acquired: Watercooling Shop
Test Results
Here are the idle test results when compared to the stock 7900GTX cooler:
eddie ek results
The EK block shaved 6°C off of the idle temps compared to the stock cooler. This is pretty impressive at idle as the stock cooler deals with idle temperatures pretty well.
The Load results:
eddie ek block
The EK block is once again impressive, managing to gain a load temperature of only 42°C. This is a great result and proves that the Eddie EK block is a true contender in the watercooling field. I am most impressed by the blocks performance.
Overclocking
Having managed an overclock of 717/870 with the Alphacool block, I was expecting the same results from the Eddie EK block. Once again, the EK block surprised my by going further than this at 725/878. This is on stock volts and just using the nVidia drivers. A serious overclocker would see this as having plenty of headroom for a very nice overclock!
«Prev 1 2 3 4 5 6 Next»
13-08-2006, 19:13:07
FarFarAway
We take a look at this high-end EK block and see how it does...
Check it here
http://www.overclock3d.net/thumb.php?id=2411
13-08-2006, 19:37:31
NickS
Rapes the alphacool man, Eddie blocks rawk. If they werent so darn expensive I'd consider one for my X1K.
13-08-2006, 19:39:05
AKtodaface
looks sick! its too bad my parts dont run hot enough to need water cooling lol
14-08-2006, 03:16:33
FarFarAway
I don't know about rapes...but it is an awesome block
14-08-2006, 03:27:45
Jim
The base looked a bit tarnished mate? Was this the camera's doing, or was the blocks base not protected with a layer of plastic?
14-08-2006, 04:11:32
FarFarAway
The base wasn't scratched at all, it just had some ingrained marks from milling. There were no surface scratches at all - these were just "stains"
Shiny doesn't always mean flat
EDIT: No layer of plastic: but adequate protection was given to the block
14-08-2006, 05:58:51
PV5150
Nice review Kemp. Loved both performance and the look, although it certainly appeared as though the base was badly oxidised. Well done
14-08-2006, 06:08:04
FarFarAway
Yeah but it was thoroughly cleaned with TIM so I don't think it was. Just milling marks. Seen it on other blocks and even though they're flat they still have marks.
Performance was awesome though so I couldn't possibly put this as a -'ive
14-08-2006, 06:40:52
PV5150
Yep agree totally. Further; you mentioned the plain packaging which is also refreshing. Some manufacturers are finally letting their products do the talking, instead of bombarding us with all the usual jargon and rhetoric on the outside packaging.
14-08-2006, 06:56:15
Dav0s
dont think u could have chosen a beter pic to sum it up ^^^
looks sexeh with the green fluid in the dark
14-08-2006, 06:57:12
FarFarAway
Oh yes!
Damn sexy. A very nice block all in all
14-08-2006, 07:36:51
FragTek
Wow very nice block, and great review Kemp! Waterblocks are kind of a PITA to do reviews on unless you're planning on draining your loop for something else anyhow.
You should really test a DD full cover block and then do a shootout and sum-up review between the alpha, eddie, and dd blocks.
15-08-2006, 02:27:51
PV5150
Awesome suggestion Fraggles, that'd certainly be a droolworthy review worth reading
19-08-2006, 19:18:20
Mullet
Nice review mate...
Should be installing my EK Sli set-up this week....seeing that UV dye has raised doubts, was set on blue....but now leaning towards green!
20-08-2006, 06:55:32
PV5150
Yeah the UV green looks lush fo' sho' I love it; actually I'm partial to Fraggles orange too in ye old 'fear and loathing'
