Fractal Design Node 202 ITX Case Review
Having recently reviewed the Define Nano S it’s now time to cast our gaze across something even smaller from Fractal. Â This time around it’s the turn of the Node 202, which as you might have guessed is part of the Node series of cases. Â From the off it’s important to recognise that measuring just 377x82x330mm (WxHxD), and the laws of physics being what they are, a case this small is not expected to be able to accommodate custom loops, or for that matter even AIOs. Â That said, it will home GPUs up to 310mm long and 47mm deep, so there’s a nod at least to the hope that the 202 is not just intended to be a posh office pizza box case.
Technical SpecificationÂ
Dimensions | 337x82x330mm (WxHxD) |
Form Factor | M-ITX |
Expansion Slots | 2 |
2.5″ | 2 |
Max GPU size | 310x145x47mm (LxHxD) |
Max CPU cooler heigh | 56mm |
Max PSU length | 130mm (SFX PSU) |
Colour | Black |
Weight | 3.5KG |
Front I/O | 2xUSB 3.0, Audio in/out |
