Fractal Node 304 Review
Fractal Node 304
Up Close - External
As we come to expect from Fractal, the Node 304 is a stylish & sleek case which is typical of the styling Fractal tends to adopt with all of their cases. With that in mind, the Node 304 is a case that is small enough to be placed almost anywhere in the home and not look out of place.
The front of the case features a brushed aluminium panel along side the Fractal Design logo, which is situated at the bottom right of the case.
Fractal Node 304     Fractal Node 304
Taking a short step back reveals a ventilated side panel, this is a feature we have come to expect with small form factor cases. The case is ventilated on both sides.
Situated on the right of the front panel is the power button along side 2x USB 3.0 slots, stereo and microphone jacks.
Fractal Node 304
To ensure the case has a degree of air-flow, Fractal have included a top ventilated panel at the front of the case, located just behind his are 2x 90mm Fractal silent series R2 fans.
Fractal Node 304
At the rear of the case we are presented with a 140mm silent series R2 exhaust fan, graphics card vent and fan controller.
Fractal Node 304
  Fractal Node 304
Fractal Node 304
«Prev 1 2 3 4 Next»
13-02-2013, 06:16:46
Not to be intruding or anything but i though the fractal fans in the case and the mounts were for 92mm fans not 90mm ? as i can only see the 92mm fan dimension listed on there site.Quote
13-02-2013, 06:47:39
They are indeed 92 mate Quote
13-02-2013, 15:04:39
Any chance you could remove the hard drive mounts and mod the case so a radiator would fit between the metal bars that are used for the drives?Quote
17-12-2014, 13:50:58
Nice looking case.... have an option on one
Tom - will a Corsair AIO cooler fit (the H90)?
