Nanoxia Deep Silence 2 Case Review
 Nanoxia Deep Silence2 Case Review
If you're a regular on the OC3D site you'll no doubt have seen the review of the DS1 just a few short months ago.  What you may not be aware of though is that Nanoxia have a mark II version of this case which can be had for about £20 less.
Thankfully Nanoxia do not appear to have changed too much (if it isn't broke, don't fix it) staying with the formula that made the  DS1 such a success.  Like the DS1, the DS2 is a "silent" case, with simple blocky aesthetics.  Sound insulation is in abundance coupled with 3 of Nanoxia's own low noise 1300rpm fans.  There's ample storage and expansion options as well as the ability to accommodate E-ATX Motherboards.  Couple this with native watercooling support and it's tempting to think that this could well be another hit for the German Manufacturer.
Don't go thinking though that the DS2 is an exact clone of the DS1, there are some subtle but important differences which to an extent explain the £20 drop in price.
Type Mid Tower
Form factor E-ATX, ATX, Micro ATX, Mini ITX
Dimensions 468x207x588mm (H,W,D)
Material 0.7mm Steel
Weight 10.95kg
5.25" 3
3.25"/2.5" 7 internal 1 external (5.25")
Case fans
 Front, 2x120mm included, 1x140mm optional
Front internal 2x120mm optional
Rear 1x120mm included
Roof, 2x120mm or 2x140mm optional
Side, 1x120mm or 1x140mm optional
Base, 1x120mm or 1x140mm optional
Max CPU cooler 165mm
Max GPU length 370mm (345 with internal bracket attached)
«Prev 1 2 3 4 5 6 7 8 Next»
29-04-2013, 08:48:33
alienware
Nice one and good to see Gary getting his hands dirty
Thanks for the review.Quote
29-04-2013, 08:51:31
tinytomlogan
Gary does loads if you look Quote
29-04-2013, 08:55:42
alienware
Yeah I know. Shame we don't see/hear him in more videos as that Thortech video was hilarious..
"Oh dear..." Quote
29-04-2013, 09:09:07
tinytomlogan
Gary just does written reviews.
The thortech video was Jim the site founder. Hes now gone and OC3D in mine alllll miiiiiiine! Quote
29-04-2013, 09:27:27
alienware
Doh !
Well that was a mix up Quote
