Nanoxia DS6 Deep Silence 6 Review
Nanoxia Deep Silence 6 Review
Is it a PC case or a danger to shipping?  When the new DS6 from Nanoxia arrived we felt we ought to notify the Coast Guard.  They usually like to know about things this big and white near the coast.  How big is it?  Well it stands just under 645mm tall.  It has a dry weight of 20Kg, and it took two chaps to deliver it, that's how big it is.  Ok so maybe it's not going to sink an ocean liner, but it sure as heck nearly sank us reviewing it.
The DS6 is the new Daddy of the Nanoxia range of low noise PC cases, and as you might imagine with all that size comes a great deal of usable space.  Not only can the DS6 accept the largest motherboards on the market and take any GPU you care to chuck into it, it can do so while providing native water cooling support for large rads in the roof and the front and while still housing up to 13 HDDs and 4 5.25" devices.  All this comes at a cost though, £200 is a lot to pay for a case, so it had better be good.
 Form Factor HPTX, E-ATX, XL-ATX, ATX, Micro-ATX, Mini-ITX
ColoursBlack, White, Anthracite
 5.25 inch drive bays, external 4
 3.5 inch drive bay2, external 2
 2.5/3.5 inch drive bays, internal 13
 Case Fan (Front) 2 x 140 mm (1,100 rpm), supplied
 Case Fan (Rear) 1 x 140 mm (1,100 rpm), supplied
 Case Fan (Top) max. 3 x 120/140 mm, 2x 140mm supplied
 Case Fan (Bottom) 2 x 120 / 1 x 140 mm
 Case Fan (Left Sidepanel) 2 x 120/140 mm
 Dimensions 644x250x655mm (HxWxD)
 material Steel and Plastic
 Max CPU Height 200mm
 Max GPU length 400mm
Radiator Support
Roof:  Up to 280mm or 360mm Radiator with push pull set up, 89mm of space available.
Front:  Up to 240 or 280mm Radiator with push pull set up, 160mm of space available. (will affect max GPU length and Motherboard support).
  1. Key Features
  2. High density noise-reducing material
  3. Can accommodate up to 13 3.5" hard drives!
  4. Two channel fan controller can control eight fans
  5. Includes five 140mm case fans
  6. Water cooling enthusiasts can mount two radiators
  7. Excellent cable management
  8. "Active" Air Chimney
«Prev 1 2 3 4 5 6 7 8 9 Next»
25-11-2013, 10:22:14
Nanoxia have been very busy indeed since he release of the DS1. Here we take a look at the Daddy of the range, the DS6
Continue ReadingQuote
25-11-2013, 11:40:00
Oooh the modding senses are tingling!! Quote
25-11-2013, 11:47:26
Waaay to white. ;D
Its a real shame about the quality, I hope it doesn't go downhill anymore. I want a Matx deep silence, that would be fantastic!Quote
