Noctua NC-U6 Chipset Cooler
With the introduction of highly overclockable CPU's like Intel's Core 2 Duo range of processors, we have seen an increase in the damand for cooling solutions that will take the demands of extra heat produced by the chipsets, but are virtually silent. With ever increasing frequency, motherboard manufacturers are turning to proven 'heatpipe technology', in order to deal with this extraneous heat. Heatpipe technology has been used on CPU heatsinks for some time now, and is testament to how effective it really is. The benefits of heatpipes when cooling is not only the heat being drawn away more efficiently, but that it allows the manufacturer to make the heatsink totally passive and silent, or include relatively low cfm fans to provide additional cooling.
Noctua, are an Austrian based aftermarket cooling company, with whom I became acquainted after reviewing their NF-R8 and NF-S12 cooling fans. They had asked if I would be interested in reviewing their new NC-U6 chipset cooler, and I eagerly jumped at the chance. The NC-U6 chipset cooler utilises heatpipe technology and is definitely a great looking cooler; but how does it perform? Let's get it into the OC3D Labs, and take a look.
NC-U6 Front Packaging NC-U6 Rear of packaging
Specifications
The NC-U6 implements a miniature-version of the well proven design of Noctua's award winning NH-U coolers. Sporting 2 Dual-Heatpipes, 29 aluminium fins and soldered joints for optimal heat-transfer, the NC-U6 is the ultimate solution when it comes to silently cooling today's high-end chipsets. The NC-U6's specifications have been taken directly from Noctua's website and included below.
Height: 85 mm
Width: 70 mm
Depth (cooling fins): 23,5 mm
Depth (socket): 33 mm
Weight: 130 g
Material: Copper (base and heat-pipes), aluminium (cooling fins), soldered joints
Mounting System: Push-Pins & Mounting-Hooks
Warranty: 6 Years
Now that we've seen the specifications of the NC-U6, let's delve a little deeper...
Packaging and Contents
The packaging that Noctua have chosen to use with the NC-U6 is a fairly standard affair, but is neatly presented and provides ample protection for the chipset cooler. The NC-U6 fits snugly into the bubble pack, and all other necessary fittings are included in behind the cooler itself.
Package contents NC-U6 mounting hardware
Thermal paste and foam shim
The installation guide provided with the NC-U6 is very well written, with ample pictorial content for the less tech minded. The NC-U6 is intended to be used on both Intel and AMD platforms, so appropriate installation hardware has been included.
The NC-U6 is shipped with mounting systems for Intel and AMD mainboards, using the existing fastening hooks or push-pin mounting holes. In order to achieve maximum compatibility with mainboards, VGA cards and CPU coolers, the NC-U6 can be turned by up to 120°.
I must admit that I had reservations about the strength of the included mounting hardware, particularly with the plastic lugs and springs. But, upon closer examination, my fears were allayed.
Noctua has also included thermal paste and a foam shim to protect the chipset transistors from shorting on the copper base. The thermal paste was particularly interesting because it appeared that the water content had separated from the TIM itself. I managed to get some degree of consistancy from the thermal goop by massaging the packet, and again coaxing the water back into the mix. However, the compound does seem extremely watery, perhaps Noctua could have a look at this problem and find some way of alleviating it. Regardless, there are alternative TIM out there, but for the sake of this review, we will be using the compound supplied.
Moving on, we shall now take a look at Noctua's NC-U6 chipset cooler in a little more detail.
«Prev 1 2 3 4 5 Next»
14-02-2007, 08:42:05
PV5150
Looking for a purely passive cooling solution with your chipset cooling? Noctua's NC-U6 chipset cooler dropped by the OC3D Review Labs and we put it through its paces. Check out the review to see what all the hype is about...
LinkQuote
14-02-2007, 08:42:46
FarFarAway
Looks damn sweet. Great review as usual Mr Peevles Quote
14-02-2007, 09:31:13
PV5150
Thanks mateQuote
14-02-2007, 09:47:31
Rastalovich
Looks really nice, I think the price tag isn`t too bad either. Definately something to consider to replace some of the awful ones mobo manufs put together.
Thing that amazes me is if u look at the item seperately, it looks like it`ll be an awkwardly looking skyscraper of a hs. But when u see it mounted in situ, surrounded by cards etc, u realize it`s more suitable than u might have thought.
Price I seen this @ Performance was about $35 >.< I was thinking it`d be cheaper dollar side.Quote
14-02-2007, 10:48:54
Mr. Smith
That is a nice little cooler. Quality review too Quote
14-02-2007, 14:44:27
NickS
Nice review. PV, how'd you measure chipset temp on P5B?Quote
14-02-2007, 15:42:50
Toxcity
Nice one PV!
I really enjoyed reading this. Looks like a pretty damn good NB cooler too! Quote
14-02-2007, 16:35:07
chudley
I cant wait till the days when i need a cooler like this, it means I have finally hid away enough money to get an update and the missus has not caught me. Quote
14-02-2007, 17:09:26
GrimReaper
hey nice reviewQuote
14-02-2007, 19:01:08
PV5150
Hey guys, thanks for the feedback. Appreciated
Thanks mate. Temps were taken via Speed Fan 4.32 beta 17 and double checked for consistency using ASUS' own PC Probe.Quote
14-02-2007, 19:07:54
NickS
Hmm. "Chipset" never showed up in PC Probe for me?Quote
14-02-2007, 22:15:45
PV5150
PC Probe shows consistently the same temp on my motherboard reading as it does in AI Suite (sytem) and Speedfan. Iirc, the winbond (W83791G) chip for the P5B Deluxe 965 chipset handles the temps from CPU and NB via the die.Quote
15-02-2007, 03:10:12
FarFarAway
They showed in PC Probe for me too Quote
