Noctua NH-D15 Review
Having resolved to write the introduction to this review before the results of the testing were known we now find ourselves sitting typing and genuinely wondering whether the refinements Noctua have made to the all conquering NH-D14 will be sufficient to lift the new "Elite Class" NH-D15 above pretty much any other air cooler on the planet.  It's certainly been a long time coming as Noctua CEO Roland Mossig explains
"In the end, it took us more than three years of continuous development, countless thermal simulations and over hundred samples to come up with a substantial improvement in efficiency. Staying true to our policy of not releasing anything we're not 100% satisfied with, we had to accept some delays in order to squeeze out the last few percent of performance, but now we're proud to finally release the NH-D15 as a worthy successor to the venerable D14."
We think it fairly safe to say then that Noctua themselves at least are certain that the new D15 has what it takes to relieve the D14 of its crown.  To give us a bit more of an idea about how it plans to do this, let's take a look at the Technical Specifications.
Intel1156, 1155, 1150, 2011
AMDAM2, AM2+, AM3, AM3+, FM1, FM2, FM2+
Dimensions Without  fans165x150x135mm (HxWxD)
Dimensions With fans165x450x161
Weight Without fans1000g
Weight with fans1320g
MaterialCopper base and heat pipes, Aluminium cooling fins, Soldered joints and Nickel plating
Fans2xNoctua NF-A15 PWM
Max rotational speed150RPM
Max rotational Speed with LNA1200 RPM
Max. Airflow140,2 m³/h
Max. Airflow with L.N.A.115,5 m³/h
Max. Acoustical Noise24,6 dB(A)
Max. Acoustical Noise with L.N.A.19,2 dB(A)
«Prev 1 2 3 4 5 6 7 Next»
26-04-2014, 12:49:55
tinytomlogan
http://www.overclock3d.net/gfx/artic...081049113l.jpg
Born of the mighty NH-D14, will the new Noctua NH-D15 be a worthy successor?
Continue ReadingQuote
26-04-2014, 13:32:56
GregPalos
Very fair conclusion. I feel Noctua does have to start making slightly "better looking" fans even if it takes away from the Noctu-esk aesthetic. I know however that noctua still doesn't look bad and even good in blue, cream and white builds. Let's hope they have a turn around!Quote
26-04-2014, 13:49:57
barnsley
Phanteks do the differing color schemes. They're incredibly sexy for air coolers and pretty much on par with the DH-14.
I've always admired the top end air coolers as they're really, stupidly quiet yet powerful (they can cool a 9590 without sounding like a jet!). I prefer pretty RAM for now so I'm sticking with AIOs.
As you said, the king is dead, long live the king.Quote
