Noctua NH-U12S Review
They say that bigger isn't always better.  For the most part I'd have to disagree.  As men we know size matters and that bigger is very often better.  Whether it be screen size, memory size, SSD capacity, Overclock, or for that matter even the size of our....Ahem.  Yes well, what we're trying to say here is that we're pretty much hard wired into a perpetual game of top trumps with all the numbers in our life.  Where size does matter though, and where the above rule starts to gain credence, is when size causes a problem, when it causes a conflict, where it gets in the way of other things, or where it's too large to fit.  Imagine that, having one so big that it's too big to fit...Get your minds out of the gutter, I am of course talking about heatsinks here, and some being too large to fit in your case, fouling your manly large RAM, obscuring your first PCI slot,  or stopping the door from shutting on your super slim case.
Enter then the Noctua NH-U12S at just 158mm tall and a mere 45mm deep without fans there's no way it's going to get in the way of your RAM, and unless you're into uber thin Mid towers you're going to be hard pushed to find a case that's too narrow for it.
The sample we have for review comes packaged with a pair of focussed airflow NF-F12 fans, which should make for some interesting temps.  Time and testing will tell.
Socket compatibility
Intel LGA2011 (Square   ILM), LGA1156, LGA1155, LGA1150 & AMD AM2, AM2+, AM3, AM3+, FM1, FM2   (backplate   required)
Height (without fan)
158 mm
Width (without fan)
125 mm
Depth (without fan)
45 mm
Height (with fan)
158 mm
Width (with fan)
125 mm
Depth (with fan)
71 mm
Weight (without fan)
580 g
Weight (with fan)
755 g
Material
Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating
Fan compatibility
120x120x25
Scope of Delivery
NF-F12 PWM   premium fan
Low-Noise Adaptor (L.N.A.)
NT-H1 high-grade thermal compound
SecuFirm2™ Mounting Kit
Anti-vibration pads and fan-clips for second NF-F12
Noctua Metal Case-Badge
Warranty
6 Years
Fan specifications
Model
Noctua NF-F12 PWM
Bearing
SSO2
Max. Rotational Speed (+/- 10%)
1500 RPM
Max. Rotational Speed with L.N.A. (+/- 10%)
1200 RPM
Min. Rotational Speed (PWM)
300 RPM
Max. Airflow
93,4 m³/h
Max. Airflow with L.N.A.
74,3 m³/h
Max. Acoustical Noise
22,4 dB(A)
Max. Acoustical Noise with L.N.A.
18,6 dB(A)
Input Power
0,6 W
Voltage Range
12 V
MTBF
> 150.000 h
«Prev 1 2 3 4 5 6 Next»
05-09-2013, 04:59:05
tinytomlogan
Lets take a look at the NH-U12S. Little brother to the by no means massive NH-U14S
http://www.overclock3d.net/gfx/artic...093035247l.JPG
Continue ReadingQuote
05-09-2013, 05:52:38
Lazlo
Cheers for that review!
I'm running this one in my rig and was thinking about adding a second fan and doing a mild overcock. So the review really hit the spot!
Tbh I didn't think this would be rewiewed since it does not exactly fall in the scope of the site (I would guess). Obviously I don't mind that at all.
Greetz LazloQuote
05-09-2013, 06:01:13
tinytomlogan
Greetz Lazlo
We review all sorts matey and Noctua has always been a favorite for us here Quote
