Noctua NH-U14S Review
It's fair to say that Noctua have established themselves something of a reputation in the air cooler market.  This is in no small part due to the excellent performance of the class leading NH-D14.  However, it wouldn't be unreasonable to note that that although the D14 is a true performer it is a little on the large size and as such it's possible that it may cause you some compatibility issues, especially if you're toting tall RAM.  Enter then the NH-U14S, a slim line single tower at only 78mm deep with the supplied NF-15 PWM fan Noctua boast a high degree of motherboard compatibility.  Although we're not expecting the NF- U14S to match or even get close to the D14 it still has a lot to live up to if it's going to wear the Noctua badge so lets have a look at the full technical Specification to see if the right ingredients are there.
Intel Compatibility
Socket 2011
Socket 1156
Socket 1155
Socket 1150
AMD Compatibility
Socket FM2
Socket FM1
Socket AM3+
Socket AM3
Socket AM2+
Socket AM2
 Dimensions without fan
 165x150x52mm (HxWxD)
 Dimensions with fan
 165x150x78mm (HxWxD)
 Fan
 NF-A15 PWM 1500RPM
Air Flow
82.5 CFM 67.9 CFM using LNA
Sound Level
24.6 dBA
19.2 dBA using LNA
Fan Speed
300   to 1500 RPM PWM
1200 RPM using LNA
Fan Connection
4 Pin PWM
Fan Dimensions
140 x 150 x 25mm
Approx Cable Length
300mm
Fan LED Colour
n/a
Materials
Nickel  Plated Copper heat pipes and base
Aluminium Fins
Heat Pipes
6 in spread "U" form
Special Features
Slim   Cooler
Anti Vibration Design
Secure Mount
Package  Contents
1 x Noctua CPU Cooler
1 x 140mm PWM Fan
SecuFirm Mount System
AntiVibration Pads
Spare 120mm Fan Clips NT-H1 Thermal Compound
«Prev 1 2 3 4 5 6 Next»
26-07-2013, 02:32:53
kittysniper
Thanks for the review, seems like a good cooler for mid tower and bitfenix prodigy type of small atx case, might try it out for my next build my current xspc rad + Silverstone fans r kind of loud.Quote
26-07-2013, 06:59:23
tinytomlogan
Then set it up properly......Quote
