NZXT Phantom 240 Review
Since the introduction of the original Phantom back in late 2010 NZXT have continued to extend the line and refine the design, offering a Phantom case at a size and budget to appease most in the market place.  We say "most", as with the 410 setting you back some £80, up to now there hasn't been a real low cost entry point into the Phantom range.  Not being one to rest on their Laurels, NZXT have remedied this with the introduction of the new Phantom 240, which comes in at just £50 and boy is it a looker.  The Phantom lineage can clearly be seen in the lines, yet the 240 appears more refined, more sculpted and, it has to be said, more mature.  Beauty though is only skin deep and although the 240 will undoubtedly score highly for its looks we will need to see what's going on under the bonnet.
SizeMid Tower
Model NumberCA-PH240-W1
Motherboard SupportATX, MICRO-ATX, MINI-ITX
Dimensions195 x 530 x 529 mm
MaterialPlastic / Steel
Product Weight8.1 Kg
5.25"3
3.5"/2.5"6 shared
Cooling
Front 2x120mm, 1 included
Rear 1x120mm included
Roof 2x120mm or 2x140mm
Bottom 1x120mm
Max CPU Cooler158mm
Max GPU length400mm w/o HDD Cage 290mm with HDD Cage
Cable management17mm
«Prev 1 2 3 4 5 6 7 8 9 Next»
04-06-2014, 07:21:57
tinytomlogan
http://www.overclock3d.net/gfx/artic...065316432l.jpg
Looks like NZXT have taken the Phantom 240 to the Gym. Just look at those sculpted lines.
Continue ReadingQuote
04-06-2014, 08:23:14
iBeInspire
If this was in black, consider me sold.Quote
04-06-2014, 09:46:47
SieB
It's weird seeing a case that has curves instead of angles.
It looks strange, but in a good way. Not a case I would buy, but a good case non the less.Quote
