NZXT Phantom 630 Review
Published: 4th February 2013 | Source: NZXT | Price: £155.99 |
Imagine what it would be like to come into the world and find yourself suddenly placed between a highly capable younger brother and a very successful older brother. you'd have to be pretty damn good to make a name for yourself. The Phantom 630, being a bit bigger than the 410, and smaller than the 820 is in exactly that position, placed, as you might imagine, directly in between its smaller and bigger brothers.
Although the 630 is also available in Gunmetal or white, the sample we have for review today is the Matte Black version. And boy is it black, or as Ford Prefect might put it "It's so....Black you can hardly make out its shape...Light just seems to fall into it" So a paint job worthy of Hotblack Desiato's stunt ship, but what else does it have going for it. Well aside from seemingly infinitely configurable hard drive bay assemblies the 630 is also capable of offering support for a considerable number of radiators and fans. We're not just talking little 120s in the back here, oh no, the 630 can take some of the big boys. 120.3s and 140.2s in the roof 140.2s in the front and 120.2s or 140.2s in the base. In short enough native watercooling support to make even the most hardened air enthusiast want to get wet. Don't go thinking that's all the 630 has to offer though, for the full fat version of the features best we have a look at the technical specification.
Dimensions | 245x627x600mm (W,H,D) |
Materials | Steel and Plastic |
Weight | 12.3kg |
Motherboard Support | XL-ATX |
Power Supply Support | ATX |
Maximum GPU Length | 325mm (507mm without HDD cage) |
Maximum CPU Cooler height | 170mm (200mm without side panel fan) |
PCI Expansion Slots | 9 |
External 5.25" Drive Bays | 4 |
Internal 3.5" Drive Bays | 6 |
Internal 2.5" Drive Bays | 8 (using 3.5" Drive Bays) |
Front I/O Panel | 2 x USB 3.0 |
Colour | Matte Black |
Removable Motherboard Tray | No |
CPU Mounting Hole in Motherboard Tray | Yes |
Cooling | |
Front | 1 x 200mm Case Fan |
Rear | 1 x 140mm Case Fan |
Top | 1 x 200mm Case Fan |
Bottom | option for 2 x 140mm or 2 x 120mm Case Fans |
Side | 1 x 120mm |
Watercooling Support |
Radiator Support | Roof 120.3 or 140.2 Rear 120.1 or 140.1 |
Just cant find any in my country yet...
Just wasn't available when I was buying, and the side panel put me off a bit.
NZXT really needs to get a replacement parts store up, so clean side panels, or windowed options can be bought - or at least replacements so if you mess it up, you aren't completely in the dark!
I was wondering about how the bottom was looking in terms of radiators, I didn't see any measurements in the review. I will probably keep the 3 hdd bay (I'm a bit of a digital pack rat) hooked in it's default position and get rid of all the rest of the bays and put the thickest 240mm rad in the bottom in push/pull that it will allow. It looks like a ton of space, so I'm guessing I could fit at least a 45mm rad in push/pull.
I'm going to probably end up getting this case, it has pretty much everything I need in terms of looks and watercooling potential. That side fan/mesh area on the side panel has a date with a jigsaw though, only thing I don't like about the case. Thanks again for the review, now I can now start ordering parts.
I'd take the switch over this just because I prefer the cleaner look to it.
Wish it had a full window instead of this window/mesh mix!
Seems to have great features for watercooling but i still too expensive for this size of a case.
http://www.overclock3d.net/gfx/artic...084713496l.jpg
Continue Reading
