Silverstone SG08 Review
Introduction and Technical Specification.
Published: 6th March 2012 | Source: Silverstone | Price: £178 |
Introduction.
The Silverstone SG08 is the latest in the line of SUGO cases. Measuring only 222 mm (w) x 190 mm (h) x 351 mm (d) and styled not just as a desktop PC but to be comfortable in the home cinema environment the 10mm thick extruded Aluminium front panel means the SG08 won't look out of place sat next to a high end home cinema amplifier or tucked in beside a simple set top box. The SG08 is able to accommodate DTX and Mini ITX boards as well as having 2 expansion slots and room for GPUs up to 12.2" in length as well as CPU coolers up to 117mm in height. All that and a Bronze certified 600W PSU.
Model No. | SST-SG08B(black) | |
Material | 10mm aluminum front panel, SECC body | |
Motherboard | ||
Multimedia | -- | |
Drive Bay | External | Slim optical x 1 |
Internal | 3.5” x 1 , 2.5”x 2 | |
Cooling System | Front | -- |
Rear | -- | |
Side | VGA fan duct with oversized vents | |
Top | 180mm Air Penetrator 700/1200rpm, 18/34dBA | |
Bottom | PSU intake vents and VGA exhaust divider | |
Internal | -- | |
Expansion Slot | 2 | |
Front I/O Port | USB3.0 x 2 | |
Power Supply | Custom 600W with 80 PLUS Bronze certification and single +12V rail | |
Operating system support | -- | |
Expansion Card | Support expansion cards up to 12.2 inches | |
Limitation of CPU cooler | 117mm | |
Limitation of PSU | 12.2" | |
Net Weight | 6 kg | |
Dimension | 222 mm (w) x 190 mm (h) x 351 mm (d) | |
Extra | -- | |
AMD Radeon HD 5970 – 12.2 " |
Model No. | SST-ST60F-SG | ||||||||||||||||||||||||||||||||||||||||||||||||||
Max. DC Output | 600W | ||||||||||||||||||||||||||||||||||||||||||||||||||
Load Range | |||||||||||||||||||||||||||||||||||||||||||||||||||
combined +3.3, +5V | 140W | ||||||||||||||||||||||||||||||||||||||||||||||||||
combined +12V | 46A / 552W | ||||||||||||||||||||||||||||||||||||||||||||||||||
Input Voltage | 90V ~ 265V(Auto Range) | ||||||||||||||||||||||||||||||||||||||||||||||||||
Input Frequency Range | 47Hz ~ 63Hz | ||||||||||||||||||||||||||||||||||||||||||||||||||
PFC | Active PFC (PF>0.95 at full load) | ||||||||||||||||||||||||||||||||||||||||||||||||||
Efficiency | 82%~85% at 20%~100% loading | ||||||||||||||||||||||||||||||||||||||||||||||||||
MTBF | 100,000 hours at 25°C, full load | ||||||||||||||||||||||||||||||||||||||||||||||||||
Operating temperature | 10°C ~ 50°C | ||||||||||||||||||||||||||||||||||||||||||||||||||
Protection | Over Current Protection | ||||||||||||||||||||||||||||||||||||||||||||||||||
Connectors | 1 x 24 / 20-Pin Motherboard connector (670mm) | ||||||||||||||||||||||||||||||||||||||||||||||||||
Color | Black (Lead-Free Paint) | ||||||||||||||||||||||||||||||||||||||||||||||||||
Cooling System | Single 120mm fan | ||||||||||||||||||||||||||||||||||||||||||||||||||
Noise Level | 17 dBA - 30dBA | ||||||||||||||||||||||||||||||||||||||||||||||||||
Dimension | 150 mm (W) x 86 mm (H) x 140 mm (D) | ||||||||||||||||||||||||||||||||||||||||||||||||||
Weight | 940g | ||||||||||||||||||||||||||||||||||||||||||||||||||
Form factor | |||||||||||||||||||||||||||||||||||||||||||||||||||
Certification | 80 PLUS Bronze | ||||||||||||||||||||||||||||||||||||||||||||||||||
Other | |||||||||||||||||||||||||||||||||||||||||||||||||||
I am pretty damn sure the front of that case shall me literally bullet proof with the 10mm of aluminium
Thankyou for taking the time to review this.
Only real gripes I have with the sugo 05/07/08 is the psu and front cables are 2 bloody long for this case, also the outer side panels feel like paper compared to the rest of the case.
A moduler psu would have been better with shorter cables.
Latest in the SUGO line of Small form factor cases from Silverstone, The SG08 steps up to the OC3D mark ready to be measured.
Continue Reading
