Water Cooling Kit Group-Test
 Water Cooling Kit Mega-test
With Water cooling becoming ever more popular, and having whetted your appetites of late with a look at the current crop of AIOs we thought we'd turn our sights on self assembly systems from four of the biggest water cooling kit manufacturers.  All of the systems on test here today have been supplied by Specialtech, well known purveyors of one of the best known water cooling candy shops you'll ever hope to find.  They all contain pretty much everything you'll need to assemble your own loop, and with the added assurance that all the gear from each manufacturer will play nicely together so you're not going to have to worry about compatibility issues.  Heck in some cases they've even included instructions!
Although reservoir, pump, contact plate, tubing and fittings may vary between the kits, they do all have something in common.  All the kits on test come with a 240mm radiator as standard.  Granted some of the kits are available with larger rads, but with the 240mm offering the greatest case compatibility it makes sense to use this size as the basis for comparison.
We'll be testing each of the systems at 4 levels of overclock with fans at both 12v and 7v.  Not only that but for good measure we'll be testing each of the rads at the highest overclock with a set of 120mm Noctua fans again at 12v and 7v both to add an element of additional comparison but also help in determining whether the performance of a specific system comes from the fans supplied or the characteristics of the radiator.  With our OCCT test taking 45mins per run that works out at 7.5 hours testing for each set up, and with 4 rigs to test that makes for a colossal 30 hours of testing alone.  For those of you who tend to skip to the graphs and the conclusion, if you want more detail with regards to quality and ease of build etc then it's best you spend a bit more time perusing each of the individual sections as there's quite a deal of detail to be had.
Overview
The technical specifications of each of the systems will be covered over the next 4 pages as there's far too much information to fit here.  Instead a little appetiser of what awaits.
EKWB  £174.95
Water Cooling Kit Mega-test     Water Cooling Kit Mega-test
XSPC  £142.95
AlphaCool  £169.99
   Water Cooling Kit Group-Test     Water Cooling Kit Mega-test
Phobya  £147.05
«Prev 1 2 3 4 5 6 7 Next»
08-07-2013, 06:38:38
bofeming
Nice review TTL, I really apreciate this beacause I was wondering to buy a kit, and I think the EK looks better for me.
Maybe in the near future I can buy some loop expansion, like other rad, better pump/res and a block for my GC.
Do you think it will be worth? Or should I buy a custom loop directly.
Must say that this gonna be my 1st custom WC project.
Thx again for the review Quote
08-07-2013, 06:45:20
SieB
Interesting read, would be good to see more reviews like this
I'm surprised at the performance of the XSPC RS rad, given that it's the thinnest out of the lot. Not much in it at all though really, unless you are trying to get the lowest temps possible, it doesn't really matter which kit you go with.Quote
08-07-2013, 06:56:13
tinytomlogan
G-Dubs did this review dude. I may own OC3D but theres VB and Gdubs doing reviews too dudioQuote
08-07-2013, 08:48:35
Greenback
Thanks Gary for the time you put in to this I have been hoping for something like this.
As SieB said the xspc rs240 result was interesting and makes you wonder how the RX240 kit would of done. (I don't expect you to do it you have done a good job here)
I think it also shows that in all fairness if you are only looking at a cpu loop and never want to upgrade the AIO's are a viable option considering they are cheaper and you could put Gt ap15's or nf-f12's with the money you would save, And probably get near on the same resultsQuote
08-07-2013, 09:35:58
tinytomlogan
The RX240 would have scored much the same as the phobya, the CPU isnt maxing the rads hence the temps. Having a bigger rad just means better low speed fan results if you look........Quote
