Water Cooling Kit Group-Test
Up Close: Phobya UC LT 240
Water Cooling Kit Mega-test
You might be wondering why there isn't a picture of the box that the Phobya kit comes in.  The answer is simple, unlike all the other kits the LT240 doesn't come in its own custom box, instead it is simply supplied as a collection of parts.  This isn't a problem in itself as the box will surely be discarded anyway, but it might go some way to explain why there are no instructions whatsoever included with the phobia kit.  And we mean none, not a sausage, nil, diddly squat.  Well you get the idea.  This might seem like no big deal if you've already slung a loop or two together, but if you haven't you might be slightly put off by this.  Granted some of the manufacturers have gone the extra mile and included extensive installation instructions, but that doesn't mean that this is a given with kits as manufacturers also bring components together like this as a way of assuring value and compatibility without the need for the consumer to shop around for all the bits and pieces involved in bringing a custom loop together.
Water Cooling Kit Group-Test     Water Cooling Kit Group-Test
Technical Specification
CPU WaterblockPhobya UC2 LT
 Price£147.05
Intel Compatability           Socket 2011     Socket 1136     Socket 1156     Socket 1155     Socket 775
AMD Compatabilityn/a
ReservoirPhobya Single 5.25" Drive Bay Reservoir
PumpPhobya DC12-220
Pump Flow Rate400 L/ph
RadiatorPhobya G-Ghanger 240 V2 Full Copper (275x125x60.5mm)
Radiator Fans2 x Phobya NB-eLoop 120mm
Fan Speed1600 rpm
Fan Noise22.5 dBA
Fan Connection3 Pin
Fittings8 x Phobya 1/4" Thread 3/8" ID - 5/8" OD Silver Compression Fittings
Tubing2 Meters Masterkleer Clear 3/8" ID - 5/8" OD Tubing
FluidNOT INCLUDED
Package Contents1 x CPU Waterblock     1 x Drive Bay Reservoir     1 x Pump     1 x 240mm Radiator     2 x 120mm Fan     2 x 120mm Fan Grill     8 x Compression Fittings     3.3 Meters of Clear Tubing     1 x HeGrease Thermal paste     PSU Bridging Plug     All Mounting Hardware
Core Components
The Phobya kit utilises a single bay reservoir that is similar to the Alphacool unit, with the exception that this one fits easily into the intended bay.  The black gauged front of the res sporting the Phobya name is removable should you want to whip out those rattle cans.  There are also ports for 5mm LEDs in the res although no LEDs are supplied.  The UC-2LT cold plate comes pre assembled for Intel sockets, with no provision in the kit for adaptation for AMD CPUs.  The cold plate itself is a hefty affair, however you do get the feeling that the plastic top cover is there to conceal the name of the OEM underneath
Those of you familiar with water cooling will no doubt recognise the fairly ubiquitous water pump used in the Phobya kit.  Nothing wrong with this, tried and tested is always a good thing.  Unlike the other kits however the pump cannot be integrated into the reservoir in any way so prepare yourself for a fair bit of head scratching as you endeavour to work out where to mount it.  It's in the Radiator department that the Phobya kit really excels.  With the G-Changer 240 V2 a smidge over 60mm thick we're pretty sure it's going to produce the goods when it comes to the torture tests.  It's not just in size where the G-Changer has the edge over some of the others on test here, with the EK and XSPC rads only having side tank ports, the G-Changer has an additional set of ports on the end of each end tank making for 4 in total, just shy of the Alphacool's fully flexible 6 ports.
Assembly and Testing
The fitting method for the Phobya Cold plate is identical to the AlphaCool unit, with even the blocks having more than a passing resemblance to each other.  Phobya have supplied 8 3/8" ID x 5/8" OD 1/4" thread chrome compression fittings along with a very generous 3.3 metres (10 foot) of MasterKleer clear tubing to help you bring it all together.  The fans included in the kit are the rather unusual NB-eLoop 120s, with red blade edges extending all the way around the interior of the cowling they look to better focus the airflow into the rad.  The bright red areas in the corners of the cowlings are actually rubber pads which protrude slightly offering a degree of vibration damping.
Once assembled the kit ran well although the noise from the pump was the highest observed in these tests.  The fans however were very quiet at 12 volts and almost silent when stepped down to the lower speed under the 7 volt supply.  It seems the blade design and the rubber mounts must be doing some good at least.  We again chose not to mount the res in the highest bay which although might be most aesthetically pleasing does make for a tiresome filling process.  On the subject of filling, the Phobya rad is he only one on test to have a bleed port built in, just a shame we couldn't access it as it as the clearance at the rear of the case didn't permit.
The high gloss acrylic front panel of the single bay reservoir looks rather elegant, with even the large Phobya name and gauge not managing to ruin the looks.  Unlike the Alphacool unit the Phobya res slipped easily into the bay, being secured by screws from each side or your cases tool-less mechanism.
«Prev 1 2 3 4 5 6 7 Next»
08-07-2013, 06:38:38
bofeming
Nice review TTL, I really apreciate this beacause I was wondering to buy a kit, and I think the EK looks better for me.
Maybe in the near future I can buy some loop expansion, like other rad, better pump/res and a block for my GC.
Do you think it will be worth? Or should I buy a custom loop directly.
Must say that this gonna be my 1st custom WC project.
Thx again for the review Quote
08-07-2013, 06:45:20
SieB
Interesting read, would be good to see more reviews like this
I'm surprised at the performance of the XSPC RS rad, given that it's the thinnest out of the lot. Not much in it at all though really, unless you are trying to get the lowest temps possible, it doesn't really matter which kit you go with.Quote
08-07-2013, 06:56:13
tinytomlogan
G-Dubs did this review dude. I may own OC3D but theres VB and Gdubs doing reviews too dudioQuote
08-07-2013, 08:48:35
Greenback
Thanks Gary for the time you put in to this I have been hoping for something like this.
As SieB said the xspc rs240 result was interesting and makes you wonder how the RX240 kit would of done. (I don't expect you to do it you have done a good job here)
I think it also shows that in all fairness if you are only looking at a cpu loop and never want to upgrade the AIO's are a viable option considering they are cheaper and you could put Gt ap15's or nf-f12's with the money you would save, And probably get near on the same resultsQuote
08-07-2013, 09:35:58
tinytomlogan
The RX240 would have scored much the same as the phobya, the CPU isnt maxing the rads hence the temps. Having a bigger rad just means better low speed fan results if you look........Quote
