XSPC D5 RX360 Water Cooling Kit Review
XSPC water cooling kits have been a firm favorite by many on the OC3D forums, rightly so with their great performance and awesome pricing they can be the basis of an awesome system if done correctly. Recently though the jungle drums started beating about XSPC offing their own version of the D5 Vario pump, this is regarded as one of if not the best water cooling pump on the planet so adding it to the XSPC line up is a master stroke. The kit comes with the Raystorm CPU block an RX360 radiator and everything else you could need to get you started excluding coolant. This is actually a good move though because coolant type & colour is a very personal choice. Seeing as the pump is a beast and the radiator would be overkill for just a CPU loop we have also added in the XSPC Razor GTX680 water block to the loop so the testing will be more real world with a CPU and GPU on test to push the radiator that little bit more.
Specifications
ManufacturerXSPC
Model NumberRayStorm D5 RX360
Intel Socket CompatibilitySocket 2011
Socket 1366
Socket 1156
Socket 1155
Socket 775
Socket 604
Socket 603
AMD Socket CompatibilitySocket FM1
Socket AM3+
Socket AM3
Socket AM2+
Socket AM2
Socekt 940
Socket 939
Socket 754
PumpXSPC D5 with Tacho Wire
Pump Flow Rate1500 l/ph
ReservoirXSPC D5 Dual Bay Reservoir
CPU WaterblockXSPC RayStorm
RadiatorXSPC RX 360 Radiator
Radiator Dimensions ( W x D x H )124 x 63 x 400 mm
Fans3 x XSPC 1650 RPM 3 Pin Case Fans
FluidNOT INCLUDED
Tubing2 Meters XSPC 7/16" ID Clear Tubing
Fittings6 x XSPC Black Chrome Compression Fittings
AccessoriesIntel Mount Kit
AMD Mount Kit
3 x 120mm Black Fan Grills
80 to 120mm Radiator Brackets
3mm Twin Blue LED with Molex Connection
5mm Blue LED with Molex Connection
24pin Power Supply Bridging Tool
K2 Thermal Paste
XSPC Razer GTX680 Water Block
ManufacturerXSPC
Model NumberRazor GTX 680
CompatibilityReference Design NVIDIA GTX 680 Graphics Cards
Thread Size1/4"
CrossFire CompatibleYes
Base MaterialCopper
Top MaterialStainless Steel
Weight0g
Dimensions185 x 123 x 25.7mm
Package ContentsXSPC Razor GTX 680 Waterblock
Mounting Kit
1/4" Plugs
Thermal Pads
Thermal Paste
Special FeaturesCNC machined copper base
CNC cut stainless steel top
1mm fins for high performance
Test Equipment
OC3D Customised CM Storm Trooper
XSPC D5 RX360 Kit & GTX680 Block
Corsair Vengeance Ram
Corsair GS800 PSU
Gigabyte X79 UD3
3930K @ 4.6 1.425v
GTX680
Video Reviews
So looking at the D5 RX360 as a basic kit on its own we would have to suggest you use this as a basis for a whole system, the high quality components do carry a heavy price tag but its a kit that is perfect for expansion. A simple GPU block added in as we have done here would be an absolute minimum to validate the initial cost but with an extra radiator you could happily cool 2 GPU's and the pump would still not be getting stressed out.
Many people may see the £290 for the kit as being expensive where it only cools the CPU and they would be right, but they would also be missing the fact this kit has been spec'd to be expanded and also expanded with ease. You could for the sake of argument add a 240mm radiator, 2 GPU blocks and a motherboard block set and have an amazingly cooled system.
As tested here today we would say the pump is still over kill in all honesty but you do have the ability to be able to turn it down to make things even quieter should you wish. We would also say the radiator is at a sweet spot with a CPU and GPU, the temps are cool enough that you can run quiet radiator spec fans and still get good temperatures. To stop all those "what if I added this" questions if you added any more components you would need higher spec fans, making the whole system louder and basically ruin it. If you need to add any more kit then we would suggest adding at least another 240mm rad, the whole team at OC3D feel that 120mm single fan rads are pointless and just add extra tubing for minimal cooling potential. 240mm or don't bother!
So to recap the XSPC D5 RX360 kit is expensive but if you understand why then you will also realise its worth every penny. Personally we wouldn't use the fittings or the rad brackets etc that comes with the kit but its handy for those of you out there that don really care what your rig looks like! We personally feel water cooling should be just as much about aesthetics as it is about cooling and hanging your rad off the side of your case with hose all over the place is never going to look nice. We understand why they are there but tbh are fed up with putting those packets in the bin!
All in all its a great kit but its for those of us that understand that water cooling needs to be done right and that to do that when running big clocks with multiple components you need to get the best kit available. With all this in mind it is without a doubt a gold award winner, those that think it should have been scored less obviously have air cooling!
Thanks to XSPC for the kit on test here today, you can discuss your thoughts on this review in the OC3D Forums.
«Prev 1 Next»
25-07-2012, 10:05:37
r3uz0r
I've heard that the xspc tubing turn brown really quickly. Is it true?Quote
25-07-2012, 10:07:46
tinytomlogan
Not that I know of.Quote
25-07-2012, 10:13:45
Lollipop
Didn't you unbox this 6 months ago? Quote
25-07-2012, 22:11:29
Jason-CL
ROFL @ your Overview video. You must have been in one hell of a good mood. Wheeee! Woooooooo! Wheeeeeee! Quote
07-08-2012, 15:38:08
Bullmecha
Does the Mayhem Aurora Coolant work with these? I know it had problems in the 750 combo.Quote
