XSPC Plexi Bay Reservoir (Black)
Introduction & Packaging
One of the hardest parts of maintaining a water cooling system has to be the removal of air bubbles. When filling the system with water, air gets trapped in components and can cause reductions in the performance of your system. In addition to this, air bubbles passing through your pump often get broken down into smaller bubbles and mix with your coolant to create a thick foam.
Water cooling companies such as Danger Den came up with a simple solution to this problem and named it a 'Reservoir'. Essentially a Plexiglass box, the Reservoir also featured an internal divider which assisted in the reduction of turbulence in the water and aided the removal of bubbles. Other advantages included easier filling and draining of your water loop, as most reservoirs feature a filler cap.
Today I'll be looking at XSPC's bay reservoir which sits neatly in a 5.25" bay and has some unique features for removing those annoying bubbles.
Having owned and reviewed XSPC products in the past, I was pretty sure of what to expect in the packaging department...
XSPC Plexi Res Packaging XSPC Plexi Res Packaging
The XSPC Bay Reservoir comes in a plain, single walled cardboard box. Although this may not be aesthetically appealing, it cuts down on the cost of production hopefully some of the savings are passed on to the end user.
XSPC Bay Res Packaging XSPC Bay Res Packaging
The reservoir is protected by a layer of bubble wrap which should prevent any light knocks from damaging the plexiglass. Larger impacts would most likely result in cracked plexiglass as the bubble wrap is only able to absorb a limited amount of shock. Luckily WaterCoolingShop normally double box these items for further protection - hopefully other resellers will do the same.
To protect the face of the reservoir from scratches, XSPC have placed a layer of sticky paper over the surface, which thankfully leaves no traces of 'sticky stuff' when removed.
Also included with the reservoir is a packet of screws for fixing the unit in place, and a blue LED to add a bit of 'bling' to your water loop.
«Prev 1 2 3 4 Next»
28-08-2006, 16:28:14
"Today I'll be taking a look at XSPC's latest addition to their water cooling lineup - the XSPC Bay Reservoir. How does this Plexiglass box differ from others available on the market? - We find out.."
28-08-2006, 17:25:12
Looks good mate, though I'm not a big fan of bay res's myself.Quote
28-08-2006, 17:53:46
Neither am I frag but this is easily one of the few bay res's I recommend. It's very well made.Quote
