Zalman CNPS 14X Review
Search Reviews
When we think of Zalman coolers we perhaps first call to mind the horizontal cylinder types, often respledant in their natural copper, or perhaps the smaller "top down" rose style coolers.  But that's not to say that Zalman don't do the "Big twin stack" type cooler, or for that matter sealed unit water coolers.  With the CNPS we see Zalman mount a very quiet 140mm fan centrally between two large heat-sink fin stacks, with six copper pipes feeding the heat up from the polished copper base plate and away from your toasty CPU.  Although quite large the CNPS 14X has a relatively simple design with little in the way of bling.  We thinks Zalman may be going for substance over style.
Compatibility
Intel LGA2011/1155/1156/1366/775 and AMD FM1/AM3+/AM3/AM2+/AM2
Max TDP
All
Installation Method
Intel and AMD - backplate, requires motherboard removal
Dimensions
140(L) x 126(W) x 159.3(H)mm
Weight
875g
Materials
Pure Copper and aluminium
Dissipation Area
10.46 cm2
Fan Type
4-Pin PWM
Fan Bearing
Long Life Bearing
Fan RPM
950 ~ 1350rpm ±10%
Noise
17 ~ 21dBA ±10%
Features
  1. 1  Powerful Cooling Performance
  2. 2  140mm PWM fan with low noise
  3. 3  6 U-Shaped dual heatpipe design
  4. 4  Two additional 140mm fans can be installed (not supplied)
  5. 5  Supplied with high performance ZM-STG2M thermal paste
  6. 6  Compatible with Intel LGA2011/1155/1156/1366/775 and AMD FM1/AM3+/AM3/AM2+/AM2
«Prev 1 2 3 4 5 6 Next»
28-11-2012, 04:46:49
tinytomlogan
http://www.overclock3d.net/gfx/artic...042237770l.jpg
With a range of no less than 31 CPU coolers it could be argued that Zalman have something for everyone. Here we take a look at one of their largest offerings, The CNPS 14X
Continue Reading
28-11-2012, 23:02:15
Bang
While I'm no expert at keeping Sandy Bridge cool, I couldn't help but look at those temps, even with the 19c ambient, and thinking 'Mmmmm, not good'
Thanks for the warning mate.
