Zalman CNPS 9900 Max Video Review
Zalman CNPS Video Review
  Zalman CPNS 9900 Max Heat Sink Review
Zalman is a name we have all heard of whether your first thought is the Reserator passive water cooling tower, their fans or even there ever growing range of heat sinks really depends on your own personal experiences with their products. The single factor that unites all products across the range is Zalman's self confessed obsession with "noiseless computing" and "silent cooling products".
Lets take a look at the specifications for the cooler on test today.
CompatibilityIntel LGA1366, LGA1155/6, LGA775 and AMD AM3, AM2+ and AM2
Cooling CapacityCompatibility300W
Dimensions94(L) x 131(W) x 152(H)mm
Weight755g
MaterialsPure Copper/Black-Pearl Nickel Plated
Dissipation Area5,402 cm2
Fan BearingLong life bearing
Fan RPM RC7P Connected900 - 1500 RPM ±10%
Fan RPM RC7P Not Connected900 - 1700 RPM ±10%
Fan Noise RC7P Connected18 - 27 dBA ±10%
Fan Noise RC7P Not Connected18 - 30 dBA ±10%
AccessoriesRC79 PWM Resistor and ZM-STG2 thermal compound
Warranty24 months
A main feature on the 9900 is "Composite Heat pipes" the image below will better explain what this is but Zalman claim up to 50% better heat transfer than traditional heat pipes. We are looking forward to seeing how this turns out in our testing.
Zalman CPNS 9900 Max Video Review
Test Setup
Gigabyte UD3R V2
Intel i7 950
Mushkin Radioactive 2000MHz
Cooler Master 690 II Advanced White Eddition
Mushkin 650W PSU
Testing
For the first test we set our i7-950 overclocked to 200x20 @ 1.25v for a clock speed of 4.0GHz. We allow the system to idle for 10 minutes and then run Prime95 'maximum heat maximum stress' setting for a further 30 minutes.
After 30 minutes we note the temperatures of all cores and the ambient temperature of the room. An average of all cores is taken, then the ambient temperature is removed from this figure and this gives us the delta temperature. Delta is the temperature difference above ambient which is a truer reflection of the heat-sink performance rather than mere maximum figures. Testing in an Igloo or the Sahara would give vastly different maximum temperatures, yet the Delta could be the same.
Sadly the cooler was not capable to withstand our testing at 4.2GHz @ 1.35v, lets move on to the video for a detailed look and explanation of our thoughts on the cooler.
The video was lengthy enough to cover pretty much every point of the cooler, but we will just cover the main points here quickly. A major plus point of this cooler is you will not have any issues what so ever with ram height compatibility, this is a major sticking point on many coolers but not with the 9900 Max. Performance at 4GHz was acceptable but we can not help feeling that for the £49 asking price when purchasing this cooler is a little steep for a 55c Delta, it would be much more desirable at £35 to £40.
Yes this section does require its own paragraph! As stated in the introduction Zalman prides itself of "noiseless computing" but sadly the 9900 Max really doesn't deserve the CNPS affiliation as unlike the earlier coolers this one isnt quiet at all. Don't get us wrong this isn't as deafening as the Thermaltake Frio but its far from quiet either. It could easily be drowned out with some headphones but there are a great number of us that use our PC's for more than gaming and when compared to some other coolers on the market we would suggest the noise performance of this cooler was borderline acceptable rather than being awarded the word silent.
Thanks to Quiet PC for the sample on test today, you can discuss your thoughts in the forums.
«Prev 1 Next»
05-02-2011, 11:24:33
m0r0n
looks can be deceiving.
ty for the presentation, a real eye-openerQuote
05-02-2011, 13:32:19
S_I_N
I had purchased one of these from the egg. But they totally buggered the whole deal by not shipping it til like a week after I ordered so I canceled it. So I never got a chance to use it. Would of been interesting to see what it did vs my el-cheapo rocketfish cooler. Which is currentky keeping me at 22c with an ambient of about 20c this is stock cpu however had a bios crash and havent re-applied oc yet.Quote
07-02-2011, 14:32:32
Rastalovich
This is simply not worth £50.Quote
07-02-2011, 14:40:13
SieB
I agree, at the beginning of the vid I thought this could be the budget cooler I have been looking for but as the video went on I went from to and then when I heard the price .
If it was £30 - £40 it would be ok but for £50 you can get a H50 and for an extra £10 a NH-D14, back to saving the pennies for me.
Quote
