Zalman Z11 Plus Review
Search Reviews
The looks of the Zalman Z11 Plus may not be too every ones taste.  If you're one of those who makes up their mind about the inherrent attributes, performance and quality of a case, or any other product for that matter, based soley upon whether you like the aesthetics of it then you're perhaps missing out on a great many treats in life.  If however you're open minded then you might be tempted to read on and see what this case is really all about.
We probably best know Zalman for their range of coolers, however a quick visit to their website will astound you at just how many products they have out there for us to spend our hard earned wedge on. From cases to coolers, Zalman prety much cover the lot.  Start searching the e-tailers and you'll also be pleasantly surprised at how well priced this Zalman kit can be.  Here we take a look at the Z11 Plus case.  A mid-tower case with rather distinctive looks, and what appears to be a pretty reasonable feature set.  Priced at just £50 the Z11 certainly appears to be good value for money, but is there substance as well as style
Enclosure Type
ATX Mid Tower
Dimensions
260(W) x 498(H) x 525(D)mm
Weight
7.4kg
Material
Plastic, Steel
Motherboard Compatibility
Standard ATX / Micro ATX
Power Supply Compatibility
Standard ATX / ATX12V
VGA Compatibility
Full Size (up to 290mm)
Expansion Slot
7
Drive Bays
5.25"
External Bay x 4
3.5"
External Bay x 1, Internal Bay x 5
5.25"/3.5"/2.5"
1 (3in-1)
Cooling
Components
Front
120mm/140mm Fan Vent x 1 (1 Fan included)
120mm/140mm Fan Vent x 2 (1 Fan included, 1 optional)
Rear
120mm Fan Vent x 1 (1 Fan included)
Side
80mm Fan Vent x 2 (2 Fan included)
Bottom
120mm/140mm Fan Vent x 1 (Fan optional)
I/O Ports
Mic x 1, Headphones x 1, USB 2.0 x 2, USB 3.0 x 2
Color
Black
«Prev 1 2 3 4 5 Next»
05-11-2012, 06:21:19
tinytomlogan
http://www.overclock3d.net/gfx/artic...065344490l.jpg
Well known for their extensive range of coolers and accessories, Zalman also produce quite a prolific range of cases. Here we take a look at the Z11 Plus.
Continue Reading
05-11-2012, 06:29:34
SieB
I like the design of this case and at £50 it's definitely a bargain.
05-11-2012, 07:39:33
SPS
Great value for money
05-11-2012, 07:58:37
Chuckers
I have the Zalman Z9 Plus and I have to say I love it, its extremely well built for the price and its reasonably quiet and because of that I'm not surprised to see the Z11 Plus scoring well, Zalman do an excellent job on their cases
05-11-2012, 15:52:18
KingNosser
I own this exact case, have had it a fair few months now, switched out the side fans for better and also fitted a fan controller while adding a bottom intake and extra top exhaust, all blue LED fans. My Tunqi tower is a pretty large cooler and in this case there is plenty of space, for the money it's a really good feature case, as mentioned with the ties behind the mobo cable management is easy in this case and the added power extension is very handy, thou I would say now fit that cable before you do anything else or your have minor issues later.
My only gripe thou small is the front panel USB3 I have to route them out the back onto the motherboard connections, I like the case much better than my old one by a long way, I got mine for £45 with P&P it offers as good a set of needs as many £70+ cases and if you buy one your be more than happy with the case for the cash you paid.
I would feel it not only deserves VFM but also a bronze award it's well laid out and you can get plenty inside clean and tidy, it's main downfall for many looking at it is it's front looks, I prefer mine on it's side with the drives popping out over the desk, so I can get inside without the need of moving it an inch.
06-11-2012, 05:46:02
sheroo
I think the aesthetics are good, looks a bit like Darth Vader.. I would remove the 80mm fans though & not even bother to replace them. Plenty of room for a home server setup, 5 in 3 hot swap in the front, fill the rest full of drives - nice.
06-11-2012, 05:48:59
neoguyver1
Yea i have one of these will show it on the rig gallery soon , I have 4 of the zalman led fans inside with a led antec on front with a 7950, i reversed the fans on the side. I think you can fit a second 2.5" hdd in optical bay area(didn't read to check if said :P).
Overall a good case for the money if you like the looks the Z9 has the same chassis bur toned down looks.
06-11-2012, 09:01:19
SnW
A bit to plastic for me...
price is great, for people that like it !!
18-11-2012, 00:08:18
andrevautour
I really like the look of this, all of these lines create a really attractive looking case in my opinion.
