AMD A10-6800K Richland Overclocked Review
Power Consumption and Temperatures
Power Consumption at the Wall
We use a mains power meter to measure what's being taken from the wall by our system. It's clear to see that overclocking the system has resulted in more power being used in all scenarios, from idle to heavy CPU stress tests.
Temperatures
Even with the two-tower 'D14 cooler running at a constant 12v we're still seeing over 80ºC when using OCCT's stress test, though the temperatures drops to below 60ºC when playing back HD movies. It was clear from the get go that the stock cooler would not have been able to withstand the extra volts needed for the overclocks.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Next»
26-06-2013, 05:01:55
Josh Weston
We've covered this APU already, but that was at completely stock settings. Let's see what it can do when we turn up the clocks!
http://www.overclock3d.net/gfx/artic...192155823l.png
Continue Reading
Quote
26-06-2013, 08:02:48
chrismjurd
what a budget beast that is Quote
26-06-2013, 09:20:21
wilkieway
Now all we need is a dual graphics review if possible.Quote
