Asus Blitz Extreme P35 Socket 775 Motherboard
Introduction & Specifications
Introduction & Specs
Back in June Overclock3D was given the opportunity to sample one of Asus' very first Intel P35 chipset based motherboards. Continuing the naming convention of many Asus predecessors, the P5K (DDR2) and P5K3 (DDR3) were both rock solid performers and managed to obtain several awards during our tests. In addition to this, both motherboards gave Asus a good chance to get to grips with Intel's latest chipset and the impending DDR3 technology.
Today we're back again, but this time looking at Asus' latest motherboard in the "Republic of Gamers" (or ROG for short) lineup. Based on the P35 chipset and utilising DDR3, the catchily named "Blitz Extreme" motherboard intends to build on the success of the P5K3 series whilst also adding plenty of extra features and performance tweaks synonymous with the ROG brand. For those of us who haven't made the jump to DDR3 yet, Asus have also created a DDR2 counterpart named the "Blitz Formula" (who thinks of these names??).
Anyway, enough of my ramblings, lets see what Asus have to say about the Blitz on their website:
The Blitz Extreme motherboard provides awesome Overclocking speeds and challenges performance limitations. Equipped with the innovative Crosslinx technology for increased performance, it utilizes the Fusion Block System - an effective 0dB fanless design cooling system with a chipset waterblock that adds onto a power user´s existing watercooling circuit to help keep operations cool. Additionally, SupremeFX II not only increases the sound quality, it also enhances aesthetic value. The Blitz Extreme also adopts the Intel P35/ICH9R chipset and supports cutting-edge DDR3 dual channel memory and CrossFire Technology - making it the Overclocker and Gamer´s first and best choice.
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in. In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
Two main features that seperate the Blitz Extreme board from some of it's P35 based counterparts are Crosslinx and the Fusion Block System. Firstly, Crosslinx is a technology designed by Asus to alleviate the performance issues when running Crossfire (2x ATI cards) on a P35 chipset motherboard. By design the P35 chipset is only able to run the 2nd PCI-E slot on the board at 4x (electrical), thus creating a substantial bottleneck and dramatically reducing the performance of the Crossfire configuration. Crosslinx reconfigures both PCI-E slots to run at 8x (electrical), greatly improving performance and allowing Crossfire to function without any issue.
Next is the Fusion Block System. Essentially a water block placed on the NorthBridge chip, the Fusion system also has the additional benefit of being connected to the SouthBridge, Mosfets and Crosslinx chip via heatpipes. Obviously you'll get a chance to take a look at this yourself later on in the review, but it's good to see Asus implementing new cooling techniques to keep the core parts of the motherboard cool and in turn aid better overclocking.
With these two main features out of the way, let's take a closer look at some of the more detailed specs:
CPU
LGA775 socket for Intel® Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Processors
Support Intel® next generation 45nm Multi-Core CPU
Compatible with Intel® 06/05B/05A processors
* Refer to www.asus.com for Intel CPU support list
** Please update the latest BIOS to support Intel 45nm CPU
Chipset
Intel® P35/ICH9R with Intel® Fast Memory Access Technology
Front Side Bus
1333 / 1066 / 800 MHz
Memory
Dual channel memory architecture
4 x DIMM, max. 8GB, DDR3-1333*/1066/800, non-ECC and un-buffered memory
* The chipset officially supports the memory frequency up to DDR3 1066MHz/DDR2 800. Due to the tuning by ASUS exclusive technology, this motherboard natively supports up to DDR3 1333/DDR2 1066MHz. Please refer to www.asus.com or user manual for Memory QVL
Expansion Slots
2 x PCI Express x16 slot, support dual graphics solution
3 x PCI Express x1, PCIex1_1 (black) is compatible with audio slot
2 x PCI 2.2
CrossFire
Support ATI CrossFire™ graphics cards (both at x8 mode)
Storage
Southbridge
- 6 x SATA 3.0 Gb/s ports
- Intel Matrix Storage Technology supports RAID 0, 1, 5 and 10.
JMicron® JMB363 PATA and SATA controller
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
- 2 x External SATA 3.0 Gb/s port (SATA On-the-Go)
LAN
Dual Gigabit LAN controllers, both featuring AI NET2
High Definition Audio
SupremeFX II Audio Card
- ADI 1988B 8-channel High Definition Audio CODEC
- Noise Filter
Coaxial, Optical S/PDIF out at back I/O
IEEE 1394a
2 x 1394a ports(1 port at back I/O, 1 port onboard)
USB
max. 12 USB2.0/1.1 ports(6 ports at mid-board, 6 ports at back panel)
Overclocking Features
Crosslinx Technology
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- CPU level Up
- AI NOS™ (Non-delay Overclocking System)
- AI Overclocking (intelligent CPU frequency tuner)
- ASUS AI Booster Utility
- O.C Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
Fusion Block System
LCD Poster
EL I/O
Onboard Switches: Power / Reset
Q-Connector
Q-Fan Plus
ASUS EZ Flash2
ASUS CrashFree BIOS3
ASUS MyLogo3
Back Panel I/O Ports
1 x PS/2 Keyboard port(purple)
1 x Optical + 1 x Coaxial S/PDIF Output
2 x External SATA
2 x LAN (RJ45) port
6 x USB 2.0/1.1 ports
1 x IEEE1394a port
1 x Clr CMOS switch
Internal I/O Connectors
3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
1 x Floppy disk drive connector
1 x IDE connector for two devices
6 x SATA connectors
8 x Fan connectors: 1 x CPU / 1 x PWR / 4 x Chassis / 2 x Optional
2 x thermal sensor connectors
1 x IEEE1394a connector
1 x S/PDIF output connector
1 x Chassis Intrusion connector
24-pin ATX Power connector
8-pin ATX 12V Power connector
1 x En/Dis-able Clr CMOS
1 x EL I/O Shield Connector
BIOS
16Mb AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.4, ACPI2.0a Multi-Language BIOS
Manageability
WOL by PME, WOR by PME, Chasis Intrusion, PXE
Accessories
Fusion Block System Accessory
DIY Pedestal
ASUS Optional Fan
3 in 1 ASUS Q-Connector Kit
UltraDMA 133/100/66 cable
Floppy disk drive cable
SATA cables
SATA power cables
2-port USB2.0 module
IEEE1394a module
EL I/O Shield
Thermal sensor cables
Cable Ties
User's manual
Software
The hottest 3D Game: S.T.A.L.K.E.R.
Support DVD:
Drivers
ASUS PC Probe II
ASUS Update
ASUS AI Suite
Futuremark ® 3DMark® 06 Advanced Edition
Kaspersky® Anti-Virus
Form Factor
ATX Form Factor, 12"x 9.6" (30.5cm x 24.5cm)
There's no denying that the Blitz Extreme is a fully loaded motherboard aimed at overclockers and gamers with features such as OC Profile (for saving settings), Voltminder LED (for displaying voltage status) and Asus C.P.R (for recovering after bad overclock) all integrated into the board and BIOS. Asus certainly haven't skimped on I/O ports either with a total of 12 USB ports, 2 eSATA ports, 2 NIC's, 6x SATA ports and a SupremeFX II High Definition add-in sound card.
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
16-08-2007, 16:22:22
JN
"After the success of Asus' first P35 chipset motherboard, we've been given the opportunity to test the tweaked out "Republic of Gamers" version affectionately known as the Blitz. Will it come out all guns blazing or bomb it big time? Read on to find out."
http://www.overclock3d.net/gfx/artic...120649525s.jpg
Asus Blitz Extreme ReviewQuote
16-08-2007, 16:42:37
ionicle
they've taken there previous motherboards, and just tweaked them to make them slightly better, added a higher pricetag, and shoved it on the market, genious really
oh, and great review
very....extensiveQuote
16-08-2007, 16:55:54
Rastalovich
I think ASUS fans will like this especially, for the reasons ionicle states. Though it does imply that this latest tweak will allow u to get that much more % of an oc.
Outside of this review, I`d like to see a study where some1 takes 1 set of a full pc hardware install, and install the OS on it a large number of times. Each time take the benchmarks like XMS has used, and find out how much a difference u get in terms of a % each time. It`ll be small, I`d think, but it would add proof to my thinking that one board beating another in a finite benchmark doesn`t necessarily mean anything, unless it goes over a %.
My theory being, u build a setup and install u`r OS fully and u`ll get 1 result. Next time around, wipe the drive, and re-install everything and u`r result will be off by a few %.Quote
