ASUS Maximus IV Gene-Z Review
Aristotle wrote that "Change in all things is sweet" and change is something that the Maximus IV knows very well.
Normally the ASUS range consists of an Extreme, a Formula and a Gene variant of the same basic design. The Maximus IV definitely changes this as the Extreme is two versions of the P67, the original and then the B3 revision which fixed the SATA issue and otherwise enhanced the basic model.
So we'd expect the Gene to be a P67 B3 based motherboard but in micro-ATX format?
Not so. The Gene is a Z68 based motherboard. So we've got a m-ATX Z68 board with onboard graphics, quite a departure from its bigger brother. However there is a Maximus IV Extreme-Z on the horizon which will be the actual bigger brother to this Maximus IV Gene-Z, rather than the current Maximus IV Extreme. It's confusing stuff indeed.
Anyway, let's see what is contained within this pocket powerhouse.
Despite its petite proportions the Gene-Z is stuffed to the gills with all the latest technology as befits a Z68-based board. We've got a couple of SATA-III ports that can handle Intel Rapid Storage Technology which uses a SSD to greatly enhance the performance of a standard mechanical drive. There are two USB 3.0 ports on the back with expansion capabilities for two more internally.
The big thing the Gene-Z has is integrated graphics. However unlike many boards that provide a plethora of outputs for IGP, the Maximus IV Gene-Z only has a HDMI output.
CPUIntel® Socket 1155 for 2nd Generation Core™ i7/Core™ i5/Core™ i3 Processors
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
ChipsetIntel® Z68
Memory4 x DIMM, Max. 32GB, DDR3 2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
 * Due to CPU behavior, DDR3 2200/2000/1800 MHz memory module will run at DDR3 2133/1866/1600 MHz frequency as default.
GraphicIntegrated Graphics Processor
VGA output support : HDMI port
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
Multi-GPU SupportSupports NVIDIA® SLI™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ Technology
Expansion Slots2 x PCIe 2.0 x16 (dual x8)
1 x PCIe 2.0 x4
StorageIntel® Z68 chipset :
2 x SATA 6Gb/s port(s), red
4 x SATA 3Gb/s port(s), gray
Support Raid 0, 1, 5, 10
Support Intel® Smart Response Technology on 2nd generation Intel® Core™ processor family
JMicron® JMB362 controller : *1
2 x eSATA 3Gb/s port(s), red
LANIntel®, 1 x Gigabit LAN Controller(s)
AudioSupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- X-Fi® Xtreme Fidelity™
- EAX® Advanced™ HD 5.0
- THX® TruStudio PRO™
- Creative ALchemy
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB PortsASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
12 x USB 2.0 port(s) (8 at back panel, black, 4 at mid-board)
Overclocking FeaturesROG Connect
Extreme Engine Digi+ :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
Mem TweakIt
ROG Extreme OC kit :
- Debug LED
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst
iROG
Extreme Tweaker
Loadline Calibration
Overclocking Protection :
- COP EX (Component Overheat Protection - EX)
- ASUS C.P.R.(CPU Parameter Recall)
Special FeaturesASUS TurboV EVO :
- CPU Level Up
ASUS Exclusive Features :
- MemOK!
- Onboard Button : Power/Reset/Clr CMOS (at back IO)
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports1 x PS/2 keyboard/mouse combo port(s)
1 x HDMI
2 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
2 x USB 3.0
8 x USB 2.0 (white port can be switched to ROG Connect)
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x Clear CMOS button(s)
Internal I/O Ports1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
6 x ProbeIt Measurement Points
1 x Power-on button(s)
1 x Reset button(s)
1 x ROG Connect switch(es)
1 x Go Button(s)
1 x Clear CMOS jumper(s)
AccessoriesUser's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
1 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x Cable ties pack(s)
1 x ROG theme label(s)
1 x 12 in 1 ROG Cable Label(s)
BIOS64Mb Flash ROM, EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
ManageabilityWfM2.0, DMI2.0, WOL by PME, WOR by PME, PXE
Support DiscSupport DVD:
- Drivers and applications
* ASUS AI Suite II
* ROG CPU-Z
* ROG GameFirst Utility
* Sound Blaster X-Fi MB2 Utility
* ROG Mem TweakIt Utility
* ASUS AI Charger+
* DAEMON Tools Pro Standard
* Kaspersky® Anti-Virus 1-year license
Form FactoruATX Form Factor
9.6 inch x 9.6 inch ( 24.4 cm x 24.4 cm )
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
29-06-2011, 14:17:12
tinytomlogan
Today we take a look at the ASUS Maximus IV Gene-Z. Does it live up to the Maximus name?
Continue ReadingQuote
29-06-2011, 14:26:46
S_I_N
niceQuote
29-06-2011, 14:31:41
V7Viper
nice review! Quote
29-06-2011, 14:34:46
SieB
Not a bad board I hope it does come in at £130 though it doesn't seem worth £160 or more
Good review as usual Bryan.Quote
29-06-2011, 14:36:24
S_I_N
damn messed that up as well meant to remove the link and it typed into my reply yeah I figured out I had the wrong post lmaoQuote
29-06-2011, 14:39:10
SieB
Originally Posted by S_I_N View Post
Newegg has them for 559$ so I'm not thinking 130L range
http://www.newegg.co...N82E16813131726
Wrong board matey, this is the Matax z68 board it's not the one from the Shadow H2O build.Quote
29-06-2011, 18:33:56
badtaylorx
yup....startin to wish i went intelQuote
30-06-2011, 18:23:43
SG12004
nice Quote
30-06-2011, 20:53:39
yggdrasil
Wish it was a bit cheaper but I will still probably get it.Quote
16-07-2011, 08:00:53
superlattice09
nice review. Wondering which is better as compared to P8Z68-V pro, of which is a few quids more expensive.Quote
17-08-2011, 11:14:17
badtaylorx
so have you guys contemplated changing this to gold or a value award??? i can get this in the states for $150 right now.....thats less than 100 ??quid?? aint'it???Quote
17-08-2011, 19:40:19
drsen
nice review,sometimes they did dip to 135, i got my gene 3 x58 for that muchQuote
18-08-2011, 16:26:58
AxJaWz
Nice board!Quote
