ASUS ROG Strix X370-F Gaming Review
Unless you've been living under a rock for the last few months then you'll be aware that the latest AMD Zen architecture has revitalised one of our favourite companies and produced an array of products which are genuine challengers for Intel's perch at the top of the mountain.
Having established that a Ryzen CPU is a serious choice for those of you who want all the benefits of umpteen cores without breaking the bank to do so, then the next thing to decide upon is a motherboard.
One of the biggest breakout ranges in recent years has to be the ASUS Strix. What started off as a curious design study based around Owls has quickly evolved into something which - whisper it - is a serious contender to the title of best product ASUS do, including high-end ROG stuff. The combination of great looks, cool features, customisable lighting and excellent performance has led many of us to cast an eye towards the Strix range and ASUS ROG department to look nervously over their shoulder.
Can the X370-F continue this great run of form?
We've said it before but it bears repeating, the X370 chipset is a match for anything available from Intel at a comparative price. Probably the biggest upgrade from the older AMD chipsets to the latest Zen one is the beefy DDR4 support. When the first X370s appeared we were seeing around 2400 MHz but some rapid BIOS revisions has seen speeds climb until now 3200 MHz is the norm. There is support for two M.2 drives and eight SATA ports. SLI and three-way CrossfireX makes sure that you can game at the best frame-rates, whilst umpteen USB ports take care of all your connectivity needs.
Elsewhere the Strix-F has all the hallmarks of a ASUS motherboard, with Sonic Radar, GameFirst, RAMDisk and AURA lighting sitting alongside a few places to install 3D Printed components. Let's take a look.
CPUAM4 socket for AMD® Ryzen™/7th Generation A-series/Athlon™ Processors
Supports AM4 Socket 14nm CPU
* Refer to www.asus.com for CPU support list.
ChipsetAMD® X370
MemoryAMD Ryzen™ Processors
4 x DIMM, max. 64GB, DDR4 3200(O.C)/2666/2400/2133 MHz, non-ECC, un-buffered memory*
AMD 7th Gen A-series/Athlon™ Processors
4 x DIMM, max. 64GB, DDR4 2400/2133 MHz, non-ECC, un-buffered memory*
Dual channel memory architecture
* Please refer to Memory QVL(Qualified Vendors List) for details.
Expansion SlotsAMD Ryzen™ Processors
 - 2 x PCIe 3.0 x16 (supports x16, x8/x8)
AMD 7th Generation A-series/Athlon™ Processors
 - 1 x PCIe 3.0 x16 (supports x8)
AMD X370 chipset
 - 1 x PCIe 2.0 x16 (max. at x4 mode)*
 - 3 x PCIe 2.0 x1
* PCIex16_3 slot shares bandwidth with PCIex1_2 and PCIex1_3.
GraphicsIntegrated AMD Radeon™ R Series Graphics in the 7th Generation A-series APU
Multi-VGA output support: HDMI and DisplayPort ports
 - Supports HDMI 1.4b with maximum resolution of 4096 x 2160 @24Hz /2560 x 1600 @60Hz
 - Supports DisplayPort 1.2 with maximum resolution of 4096 x [email protected]
 - Maximum shared memory of 2048 MB
Multi-GPUSupports NVIDIA® 2-Way SLI™ Technology
Supports AMD® 3-Way CrossFireX™ Technology
StorageAMD Ryzen™ Processors
 - 1 x M.2 Socket 3 with M Key, type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
 - 1 x M.2 Socket 3 with M Key, type 2242/2260/2280/22110(SATA mode) storage devices support
AMD X370 chipset with RAID 0, 1, 10 support
 - 8 x SATA 6Gb/s ports
LANIntel® Ethernet Controller I211-AT
Anti-surge LANGuard
ROG GameFirst IV
AudioSupremeFX S1220A 8-Channel High Definition Audio CODEC
 - Supports up to 32-Bit/192kHz playback*
 - High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
 - Impedance sense for front and rear headphone outputs
 - SupremeFX Shielding Technology
 - Dual Headpone Amplifiers
 - Jack-detection, Multi-streaming, and Front Panel Jack-retasking
 - Optical S/PDIF out port at back panel
Audio Feature:
 - Sonic Studio III
 - Sonic Radar III
*Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
USBAMD Ryzen™/7th Generation A-series/Athlon™ Processors
 - 4 x USB 3.0 ports (4 ports at back panel[blue])
AMD X370 chipset:
 - 1 x USB 3.1 front panel connector
 - 6 x USB 3.0 ports (2 ports at back panel[blue], 4 ports at mid-board)
 - 4 x USB 2.0 ports (2 ports at back panel, 2 ports at mid-board)
ASMedia® USB 3.1 controller:
 - 2 x USB 3.1 ports (2 ports at back panel, Type-A and Type-C)
ROG Exclusive FeaturesROG RAMCache II
ROG GameFirst IV*
ROG Overwolf
ROG CPU-Z
ROG CloneDrive
*ROG GameFirst IV is only available for Windows® 10 64-bit
Special FeaturesPerformance Optimization
  5-Way Optimization
 - Whole system optimization with a single click! Perfectly consolidates better CPU performance, power saving, digital power control, system cooling and app usages.
    Digi+VRM
    EPU
    - EPU
    TPU
   - Auto Tuning, TurboV, GPU Boost
   Fan Xpert 4
   - featuring Fan Auto Tuning function and multiple thermistors selection for optimized system cooling control
ASUS EZ DIY
 - ASUS CrashFree BIOS 3
 - ASUS EZ Flash 3
ASUS Q-Design
 - Q-Shield
 - Q-LED (CPU, DRAM, VGA, Boot Device LED)
 - Q-Slot
 - Q-DIMM
Gamer's Guardian
 - SafeSlot
 - DIGI+ VRM
 - DRAM Overcurrent Protection
 - ESD Guards on LAN, Audio, KBMS and USB3.0/2.0 ports
 - Highly Durable Components
 - Stainless Steel Back I/O
ASUS Exclusive Features
 - AURA Lighting Control
 - 3D Printing Friendly design
 - AI Suite 3
 - AI Charger
Back panel I/O ports1 x HDMI
1 x DisplayPort
2 x USB 3.1 ports ( 1 x Type-C [black] and 1 x Type-A [red] )
6 x USB 3.0 ports [blue]
2 x USB 2.0 ports [black]
1 x Anti-surge LAN (RJ45) port
1 x Optical S/PDIF out
5 x audio jacks
Internal I/O connectors1 x USB 3.1 front panel connector
2 x USB 3.0 headers support additional 4 USB 3.0 ports
1 x USB 2.0 header supports additional 2 USB 2.0 ports
8 x SATA 6Gb/s connectors
1 x M.2 Socket 3 for M Key, type 2242/2260/2280/22110 storage devices support
1 x 4-Pin CPU fan connector
1 x 4-Pin CPU_OPT fan connector
1 x 4-Pin AIO_PUMP connector
1 x 4-Pin W_PUMP+ connector
3 x 4-Pin Chassis fan connectors
1 x Thermal sensor connector
2 x RGB headers
1 x 24-pin EATX power connector
1 x 8-pin EATX 12V power connector
1 x System panel connector
1 x Front panel audio connector (AAFP)
1 x Clear CMOS jumper (2-pin)
AccessoryUser guide
Support DVD
I/O Shield
1 x SLI™ HB Bridge(2-way-M)
4 x SATA 6Gb/s Cables
1 x M.2 Screw Package
1 x 3D Printing Mount
1 x RGB LED extension cable
1 x 10-in-1 ROG cable label
1 x ROG Strix sticker
1 x cable tie package
BIOS128 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.0, ACPI 6.1, Multi-language BIOS,
ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Last Modified log,
F12 PrintScreen and ASUS DRAM SPD (Serial Presence Detect) memory information
ManageabilityWfM 2.0, WOL by PME, PXE
Support DVD contents Drivers
 ASUS Utilities
 Anti-virus software
Operating System SupportWindows® 10 64-bit
Form FactorATX Form Factor
12 inch x 9.6 inch (30.5cm x 24.4cm)
«Prev 1 2 3 4 Next»
16-06-2017, 14:25:17
GiantKiwi
Think I'll be getting one of these to replace the utter garbage that is the Asus Prime X370 Pro (on Number #4 now through RMA's, still no working RAM clocking despite now having 5 different kits listed on the QVL), maybe it will actually get BIOS updates more regularly as well Quote
17-06-2017, 01:53:09
Avet
Nice review. Clean and precise. I agree with Tom on RGB Chipset heatsink, but we can survive. This is the perfect middle range board.Quote
17-06-2017, 02:35:07
NeverBackDown
I think I like this as my 2nd favorite looking board. Behind the Pro Carbon, but I'd probably get this over that due to a more than likely better BIOS.Quote
17-06-2017, 03:31:56
g0ggles1994
Sweet review TTL! Definitely going to get one of these if my Carbon's BIOS doesn't improve in the AGESA 1.0.0.6 update.Quote
17-06-2017, 11:29:59
AngryGoldfish
I do believe this will be the motherboard I go for. Thanks for the quick review.Quote
