Club3D R9 290 Royal Ace Review
The last generation of AMD Radeon cards had a few that stood out about the rest, and one company that really nailed it on with all the different versions was Club3D.
Indeed the cards they provided in the last generation were so good that their HD7970 was the spine of our Ivy Bridge test bench. Given how much abuse our test rigs get we required one that was bulletproof, and in all the time we chopped and changed motherboards, testing CPUs to their limits, and generally mucking about, it never let us down once.
So their cards equipped with the Tahiti core were robust and powerful, so how does their newest addition to the Poker range, the R9 290 Royal Ace, stack up.
With the 1040MHz clock speed and plenty of cooling capacity, the Royal Ace (stylised royalAce) should give a good example of whether there is enough in a R9 290 to make the R9 290X worthy of investment, or if a good 290 can still run with the hounds.
Model
Product Name: R9 290 royalAce
Product Series: R9
Item Code: CGAX-R9298SO
EAN Code: 8717249400615
Interface
Bus Interface: PCI Express 3.0
Chipset
GPU Chipset: Hawaii Pro
GPU Clock: ~ 1040 MHz
Stream Processors: 2560
Multi-GPU
Multi-GPU: Dual CrossFire Ready
Memory
Memory Size: 4096MB
Memory Interface: 512BIT
Memory Type: GDDR5
Memory Clock: 5400 MHz
Cooling
Cooling Type: Active Tripple Fan CoolStream
TDP
Idle: 20W
Idle ZCP mode enabled: 3W
Maximum load: 250W
3D API
DirectX version: 11.2 capable graphics
OpenGL version: 4.2
OpenCL version: 1.2
Dimensions
Slot Width: 3 Slots
Profile: Standard ATX profile
Card Size: 308x125x53 mm
Weight
Card Weight: 1410 grams
Output Configuration
DVI: 2x Dual-Link DVI-D
HDMI: 1x version 1.4a
DisplayPort: 1x version 1.2
HDCP ready: YES
RAMDAC: 400MHz
Maximum Resolution Single-Link DVI: 1920x1200
Maximum Resolution Dual-Link DVI: 2560x1600
Maximum Resolution HDMI 1.4a: 4096x3112
Maximum Resolution Mini DP 1.2: 4096x2160
Maximum Outputs Simultaneously: 4
Maximum Display support: 6 (Via DisplayPort and using the MST Hub, please refer to CSV-5300
In the package
Club 3D AMD R9 290 royalAce graphic card
Club 3D knob hanger
Driver & E-Manual CD
Quick install guide
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Next»
20-06-2014, 06:36:21
tinytomlogan
http://www.overclock3d.net/gfx/artic...092959940l.JPG
Today we're looking at a tri-fan card from Club3D, the Royal Ace R9 290.
Continue ReadingQuote
20-06-2014, 08:00:10
barnsley
Nice to have another 290 with mastered cooling. Its interesting how that vendors that specialise in AMD (with the exception of XFX) have managed to tame the temperatures. Its a shame none of them have blower type coolers :I.Quote
20-06-2014, 09:22:26
Excalabur50
Hey Tom watched the video and YES the sound is MUCH!!! better although I have noticed there seems to be some weird rendering issues in the last few vids you have done, where things flash and slightly repeat is the best way to describe it, but yeah dont know what going on with that but thought I should mention itQuote
20-06-2014, 09:23:09
WYP
I do love the backplate on this card, and those are some pretty impressive clocks for a stock 290.
One thing I would like to say though, is there any need to run Cloud gate on these high end GPUs? It is a score that I, and I'm sure many others, don't want to see.
Sky diver would be more relevant, but i do understand that there wouldn't be many cards to compare score though.
You new mic sounds good Tom.Quote
20-06-2014, 10:23:01
RickPlaysWarr
Hi Tom
Very nice looking card. I like the look of the shroud and back plate. Are the club 3D cards only available in Europe? I tried to find a price from a USA E-Tailer and could not find it for sale.
On the audio quality. It is much improved. Your voice sounds good, not brittle, or thin. It provides a nice rounded full sound. Noise from the background is not apparent and that is a good thing. Is it a Omni-directional pattern mic or a Cardioid pattern one?
Thanks again
--Rick-Quote
20-06-2014, 17:57:45
Dicehunter
Great sound on the video but there's quite a bit of echoQuote
20-06-2014, 19:07:08
SieB
Good to see another well done 290, the heat sink is very similar to the one on the Tri-X.Quote
21-06-2014, 22:42:52
Deadtroopers
Sourcing a build for my nephew. This looks the part. Excellent review as always. Nice tribute to a fine comic. Sound wise, you seem a tad shriller. I too noticed slight video glitches. Nothing off putting mind. Other than that it's all gravy.
Chin Chin.Quote
22-06-2014, 17:08:25
Grodmanen
how new is this card? there aren't so many in swedenQuote
22-06-2014, 22:35:14
Wraith
Great write up and top job on the video as for the sound it was tip top here very nice card from Club 3D I like the simple clean look it just begs to be painted and OC'd. And love the homage to one of our greatest comics R.I.P Rik "The peoples poet" Mayall, you will be sorely missed.Quote
26-06-2014, 10:25:09
Silver Sparrow
Does this card use the reference board design?
Besides the odd flickering (usually during transitions) nice video
p.s classic Rooney comparison!Quote
14-07-2014, 16:13:43
randomite88
Hello! Thank you for the write up. I had a question about the Hitman: Absolution benchmark.
Are those FPS numbers from the built-in benchmark of the china-town sequence?Quote
14-07-2014, 16:31:10
NeverBackDown
Yes. Why would he benchmark himself when the game already has one? lolQuote
14-07-2014, 16:45:27
MadShadow
If you asked that question to Linus, he would tear you apart. Some people really believe that actual gameplay is more important (not Tom). Quote
15-07-2014, 06:38:25
tinytomlogan
Game play requires playing the same level and playing a LOT more of it to get a decent average score..... Fixed benchmarks are more accurrate unless you are talking multiplayer and I wouldnt want to go ruin games for people like that Quote
15-07-2014, 07:00:46
MadShadow
Yeah I understand that, and it takes WAYYY too much work. I also agree that fixed benchmarks are better as they provide consistent results Quote
