Gigabyte Z77X-UD5H Review
The UD5 variant of the Gigabyte line of motherboards is one of the most popular, providing the perfect balance between features and affordability. So we are unlikely to find a better candidate to perform our first Core i7-3770K overclocking tests on.
Now rather than go through some big preamble to explain things you've only just read in the Core i7-3770K/Intel DZ77GA-70K review we'll crack on with what the Gigabyte UD5 brings to the table.
The most obvious change is that, currently at least, there isn't a UD7 model around, or even on the drawing board. So this is the premium model in the Gigabyte Z77 range. For those of us who loved either the gold and black heatsinks of the Z68 UD7, or the black and orange of the X79 UD7, this is quite disappointing. But we know the UD5 has a lot of charm of its own without necessarily having the bling factor.
Casting your eye down the technical specifications for the Z77X UD5H it's clear that this is an evolution of the concepts we saw on the Z68, just turned up to eleven.
CPU
  1. Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
  2. L3 cache varies with CPU
(Some Intel® Core™ processors require a graphic card, please refer "CPU support List" for more information.)
Chipset
  1. Intel® Z77 Express Chipset
Memory
  1. 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
    Dual channel memory architecture
  2. Support for DDR3 2400(OC)/1600/1333/1066 MHz memory modules
  3. Support for non-ECC memory modules
  4. Support for Extreme Memory Profile (XMP) memory modules
Onboard Graphics
  1. 1 x D-Sub port
  2. 1 x DVI-D port, supporting a maximum resolution of 1920x1200
    * The DVI-D port does not support D-Sub connection by adapter.
  3. 1 x HDMI port, supporting a maximum resolution of 1920x1200
  4. 1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
  1. Realtek ALC898 codec
  2. Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
  3. High Definition Audio
  4. 2/4/5.1/7.1-channel
  5. Support for S/PDIF Out
LAN
  1. 1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
  2. 1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
    * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
    * The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  3. 1 x PCI Express x16 slot, running at x4 (PCIEX4)
    * The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
    * The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
    (The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
  4. 3 x PCI Express x1 slots
    (All PCI Express x1 slots conform to PCI Express 2.0 standard.)
  5. 1 x PCI slot
Multi-Graphics Technology
  1. Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage InterfaceChipset:
  1. 2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
  2. 4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
  3. 1 x mSATA connector
    * The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
  4. Support for RAID 0, RAID 1, RAID 5, and RAID 10
    * When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
2 x Marvell 88SE9172 chips:
  1. 3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
  2. 1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
  3. Support for RAID 0 and RAID 1
USBChipset:
  1. Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
  2. Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs:
  1. Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
    * In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
    * Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394VIA VT6308 chip:
  1. Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
Internal I/O Connectors
  1. 1 x 24-pin ATX main power connector
  2. 1 x 8-pin ATX 12V power connector
  3. 1 x PCIe power connector
  4. 5 x SATA 6Gb/s connectors
  5. 4 x SATA 3Gb/s connectors
  6. 1 x mSATA connector
  7. 1 x CPU fan header
  8. 4 x system fan headers
  9. 1 x front panel header
  10. 1 x front panel audio header
  11. 1 x S/PDIF Out header
  12. 3 x USB 3.0/2.0 headers
  13. 2 x USB 2.0/1.1 headers
  14. 1 x Clear CMOS jumper
  15. 1 x Trusted Platform Module (TPM) header
  16. 1 x power button
  17. 1 x reset button
  18. 1 x Clear CMOS button
  19. 1 x heatsink LED power connector
  20. 1 x BIOS Switch
  21. Voltage Measurement Points
Back Panel Connectors
  1. 1 x D-Sub port
  2. 1 x DVI-D port
  3. 1 x optical S/PDIF Out connector
  4. 1 x HDMI port
  5. 1 x DisplayPort
  6. 1 x eSATA 6Gb/s connector
  7. 4 x USB 3.0/2.0 ports
  8. 2 x USB 2.0/1.0 ports
  9. 1 x IEEE 1394a port
  10. 2 x RJ-45 ports
  11. 6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
  1. iTE I/O Controller Chip
H/W Monitoring
  1. System voltage detection
  2. CPU/System temperature detection
  3. CPU/System fan speed detection
  4. CPU overheating warning
  5. CPU/System fan fail warning
  6. CPU/System fan speed control
    * Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
  1. 2 x 64 Mbit flash
  2. Use of licensed AMI EFI BIOS
  3. Support for DualBIOS™
  4. PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
  1. Support for @BIOS
  2. Support for Q-Flash
  3. Support for Xpress Install
  4. Support for Xpress Recovery2
  5. Support for eXtreme Hard Drive (X.H.D)
  6. Support for Auto Green
  7. Support for ON/OFF Charge
  8. Support for Q-Share
  9. Support for 3D Power
  10. Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
  1. Norton Internet Security (OEM version)
  2. Intel® Rapid Start Technology
  3. Intel® Smart Connect Technology
  4. Intel® Smart Response Technology
  5. LucidLogix Virtu MVP
Form Factor
  1. ATX Form Factor; 30.5cm x 24.4cm
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
23-04-2012, 12:03:41
tinytomlogan
With the heavy trimming that their range has got, the Gigabyte UD5 is expected to be the top-end product in their Z77 range. Does it live up to the title?
Continue ReadingQuote
23-04-2012, 13:25:18
MaXiMiZe
Nice review Quote
23-04-2012, 14:47:35
MSIRawZ
Just FYI, we have 15 free Antec Kuhler 620 Liquid Water CPU Coolers left with this board - http://www.aria.co.uk/Products/Components/Motherboards+-+Intel/Socket+1155+-+Intel+Z77/GIGABYTE+GA-Z77X-UD5H+Intel+Z77+Socket+1155+DDR3+PCI-Express+Motherboard+w%2F+FREE+Water-Cooler!+?productId=49181Quote
23-04-2012, 15:20:23
Master&Puppet
Another good review though I'm not sure IB was worth your (plural) time! I was so hoping that the early reports of heat and similar overclock outputs would be wrong but alas there is very little to pick between these 1155 chips.Quote
23-04-2012, 16:35:07
hellhole
Nice review mate!
I've got my Z77X-UD5H sitting in my Cooler Master Cosmos 2 & it looks very small lol...
Just waiting on Ivy Bridges to hit Aussie shores and i can boot it up =DQuote
24-04-2012, 11:09:27
MaXiMiZe
^^ Bet you can't wait. Am I right in saying that this board is in direct competition with the P8Z77 deluxe from Asus?Quote
25-04-2012, 08:17:59
D3FiANC3
More or less. The WiFi version is a bit closer still.Quote
14-05-2012, 14:09:12
Ghost623
I bought this board/chip after the review here, upgrading from a Phenom x6 1100T, and its a hellofa upgrade from where Im coming from.. However, I call fowl on the overclock. You say its 1.3 on the vcore, but the cpuz shows 1.0. I cant get anything near that. I am extremely curious how you were able to hit 4.8, because the best I can do is 4.5 @ 1.2 I have tried a few times trying to hit 4.8 but have been unable to (its water cooled with corsair H80). I would like to see what you did to achieve this speed. Your overclock settings screencaps are just where you can make changes, not the actual changes themself to what you tuned everything to.
Quote
25-05-2012, 09:47:17
Master&Puppet
Well he said "The Core i7-3770K is set to 1.32v on the vCore, and a multiplier of 48." That seems right to me.
TTL probably did an offset overclock so that the core is only supplied with the volts when it needs them under load as opposed to fixing a straight 1.32v.
http://forum.overclock3d.net/index.php?/topic/39090-offset-mode-overclocking-starter-guide-and-thread/Quote
