Intel Core i7 930 Review
Intel have been churning out i7 920s for so long that their fabrication section have absolutely got the design and production process nailed. The original 920 C wasn't exactly bad, but it definitely suffered from a little too much heat and the overclocking abilities varied wildly depending upon the batch your processor came out of. Some barely cracked 3GHz while others found 4GHz to be a breeze.
Intel nearly fixed this with the release of the D0 stepping variant of the 920. This had much more consistent performance although some still did better than others. The main reason for the more reliable overclocking ability was the reduction in the heat output which was such a large part of the 920 C0/1 limitations.
Enter the 930. Still 45nm and, at a glance, the main difference is the increase from a base multiplier of 20 to a new base of 21. This has the naturally effect of increasing the base clock from 2.66GHz to 2.8GHz. So we get a little extra performance at stock but otherwise we can't really see the need for an entirely new model designation.
The move from the i7 920 to i7 930 is even more puzzling when we see it isn't 32nm, but also hasn't got the new AES instructions that enabled the 980x to demolish encryption tasks with ease.
Processor Numberi7-930
# of Cores4
# of Threads8
Clock Speed2.8 GHz
Max Turbo Frequency3.06 GHz
Intel® Smart Cache8 MB
Bus/Core Ratio21
Intel® QPI Speed4.8 GT/s
# of QPI Links1
Instruction Set64-bit
Instruction Set ExtensionsSSE4.2
EmbeddedNo
Supplemental SKUNo
Lithography45 nm
Max TDP130 W
VID Voltage Range0.800V-1.375V
So far, so uninteresting. Maybe like many hardware items there is something lurking within that doesn't show up in a pure specification list.
«Prev 1 2 3 4 5 6 7 Next»
16-04-2010, 09:41:04
alexhull24
On paper, totally uninteresting, but in practice, amazing!
Why is it happier with such lower voltages if the process is the same size? I don't know a lot about the intricacies of CPU production, but I'm interested to know what was actually changed, as going by the spec sheet doesn't yield much information.
A CPU like this should be good for many years, despite intel inevitably changing socket design in the not too distant future.Quote
16-04-2010, 10:43:47
Runebeard
That's just staggering! So glad I'm getting one of these! Maybe I'll see if I can match your "sweet spot"...Quote
16-04-2010, 11:56:24
a8875624
Will the 32nm chips be out this summer then? I imagine they will be able to break 4GHz at lower voltages?
The 3.8GHz@ 1.11v is ridiculous, but in terms of speed alone, it does not seem to offer that much advantage over the slightly cheaper 920 (£40 on scan.co.uk)Quote
17-04-2010, 08:39:05
Steve-O-
WOW! 3.8 at 1.11v... It was a good thing I wasn't drinking anything. And with that low of voltage temps must be amazing! (I skipped to the conclusion Sorry)Quote
17-04-2010, 14:39:53
ppuff
They charge more for the 930 over there? By me its the same price as 920. $199 U.S.Quote
