MSI X58 Platinum Motherboard
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Â
Â
ViMark is the latest addition to the OC3D motherboard testing process and a relatively new benchmarking application in general. Designed to take the inaccuracies and guesswork out of measuring the time taken to encode video files, ViMark produces easily comparable and consistent results for encoding raw video into Windows Media, Quicktime, AVI and Gif formats. As always, a total of 5 benchmark runs were performed with the highest and lowest scores removed and an average calculated from the remaining 3 scores.
Â
Â
7-Zip is an open source Winzip-style file compression utility that has the ability to compress and decompress many file formats including its own .7z compression scheme. 7-Zip also comes complete with its own benchmarking utility for gauging the compression and decompression speed of the system that it is installed on.
 Â
Â
Results Observations
Once more we see that the results are very close with Sisoft again unable to distinguish between the two motherboards. ViMark and 7-Zip however, clearly favoured the MSI Platinum for its encoding and compression abilities where it outperformed the P6T Deluxe by a fair margin.
Let’s move on to our 3D Benchmarks…
