ASUS ENGTX260 TOP 896MB (NVIDIA GTX260)
Â
Crysis is without doubt one of the most visually stunning and hardware-challenging games to date. By using CrysisBench – a tool developed independently of Crysis – we performed a total of 5 timedemo benchmarks using a GPU-intensive pre-recorded demo. To ensure the most accurate results, the highest and lowest benchmark scores were then removed and an average calculated from the remaining three.
Â
Â
Â
With only 4FPS between the GTX280 and ASUS’ overclocked ENGTX260 TOP at both both resolution settings, the GTX260 takes the upper-hand once again when we switch to the CPF scale. Costing a full £4 less per frame at 1900×1200 and over £3 cheaper at 1280×1024, it’s clear what the better choice is when going for the green team on a budget.
Â
Â
Â
F.E.A.R. is a game based on the Lithtech Jupiter EX engine. It has volumetric lighting, soft shadows, parallax mapping and particle effects. All results were recorded using F.R.A.P.S, with a total of 5 identical runs through the same area of the game. The highest and lowest results were then removed, with an average being calculated from the remaining 3 results.
Â
Â
Â
Once again, the GTX260 doesn’t have quite what it takes to beat out the GTX280 despite the generous ASUS overclock. However, with only 15-20FPS between the two cards and frame rates just shy of 200FPS, the difference does become quite negligible. Interestingly, the GTX260 also comes within £0.30-0.40 of the HD4850 at both resolutions, showing that its £100 higher price tag is almost made up for with extra performance.
