ASUS GTX750 Ti Review
Overclocking, Temperatures and 'Extreme' Tests
ASUS GTX750Ti Review
We have an entirely new experience with the ASUS GTX750Ti. With no voltage tweaking at all we could push the ASUS GPU Tweak software to the stops and the card just merrily kept on ticking along. In fact it overclocked so well that we discovered a firmware limit to the overclock, which is why we haven't put the results into our regular graphs.
However, take a look at the GPUz and the GPU Boost 2.0 speed that we attained thanks to the awesome cooler. Remember that this is without any voltage tweaking at all, 1350MHz on the Maxwell GM104 core. Insanity.
ASUS GTX750Ti Review    ASUS GTX750Ti Review
10°C cooler than the reference design, and absolutely silent. Everything we could wish for in a cooler to be honest.
Overclock Benefits
As we said the card 'Boosted' to a good enough speed that, coupled to the manual overclocking limits we encountered, mean that we're awaiting a potential fix before unleashing the card in our battery of benchmarks. Nonetheless there is clearly a LOT of extra performance hiding under the hood of the ASUS GTX750Ti.
07-03-2014, 08:25:49
Not bad for a lower end card.
I think there is a typo in the AVP graph for the Club3D 7950 Royal King though.
EDIT: No typo, just seems the 7950 royal king got worse performance than all the other 7950s in AVP for some reason. The HIS 7950 got 78fps for example.Quote
07-03-2014, 09:11:33
Regarding the strange placement of the power connector, if you look at the PCB, you'll notice the GPU is towards the back of the card and power delivery circuitry is near the power connector.
If they wanted to place the power connector where it normally is, it would have meant running metal tracks almost the full length of the PCB carrying a reasonable amount of current which wouldn't be a good idea really.Quote
07-03-2014, 17:18:40
That you reached a firmware limit in the overclock is interesting. I hope they will change this in a later update if its not a core restriction. IF thats the case right across the board for Maxwell cards then it could be an exciting time for GFX card overclockingQuote
