ASUS GTX750 Ti Review
Up Close and Test Setup
ASUS GTX750Ti Review
Up Close
Whereas the nVidia GTX750Ti looked like a card of yore, the ASUS really could pass for a normal ASUS offering, just on a reduced scale. The cooler is almost overkill for the job, so we're certain that the GPU Boost 2.0 will be able to maximise the cards potential whilst keeping our ears untroubled.
ASUS GTX750Ti Review     ASUS GTX750Ti Review
Probably the strangest decision is the one to move the 6pin PCIe power input from its regular position in the top right hand corner across to the left hand side near the PCI bracket itself. This is beneficial for cable routing in a ITX case, but a royal pain in the proverbials for the rest of us.
Test Setup
ASUS GTX750Ti
Intel Core i7-3960X @ 4.6GHz
ASUS Rampage IV Extreme
Corsair Dominator Platinum
Corsair AX1200i
Corsair Neutron GTX
Corsair H100i
Windows 7 x64
07-03-2014, 07:04:03
tinytomlogan
http://www.overclock3d.net/gfx/artic...184940184l.jpg
Following the recent launch of the Maxwell architecture on the GTX750Ti, we take a look at the first partner card from ASUS.
Continue ReadingQuote
07-03-2014, 08:25:49
SieB
Not bad for a lower end card.
I think there is a typo in the AVP graph for the Club3D 7950 Royal King though.
EDIT: No typo, just seems the 7950 royal king got worse performance than all the other 7950s in AVP for some reason. The HIS 7950 got 78fps for example.Quote
07-03-2014, 09:11:33
Zoot
Regarding the strange placement of the power connector, if you look at the PCB, you'll notice the GPU is towards the back of the card and power delivery circuitry is near the power connector.
If they wanted to place the power connector where it normally is, it would have meant running metal tracks almost the full length of the PCB carrying a reasonable amount of current which wouldn't be a good idea really.Quote
07-03-2014, 17:18:40
Conchubair
That you reached a firmware limit in the overclock is interesting. I hope they will change this in a later update if its not a core restriction. IF thats the case right across the board for Maxwell cards then it could be an exciting time for GFX card overclockingQuote
