ASUS GTX750 Ti Review
Unigine Heaven
ASUS GTX750Ti Review
Unigine Heaven
We've often commented here at OC3D Towers that Unigine is a clear indication of the amount of performance you can expect. It's probably no surprise then that the result bears out those we've seen so far with the ASUS card a notch above the reference model, albeit still in touching distance.
0xAA
8xAA
07-03-2014, 08:25:49
SieB
Not bad for a lower end card.
I think there is a typo in the AVP graph for the Club3D 7950 Royal King though.
EDIT: No typo, just seems the 7950 royal king got worse performance than all the other 7950s in AVP for some reason. The HIS 7950 got 78fps for example.Quote
07-03-2014, 09:11:33
Zoot
Regarding the strange placement of the power connector, if you look at the PCB, you'll notice the GPU is towards the back of the card and power delivery circuitry is near the power connector.
If they wanted to place the power connector where it normally is, it would have meant running metal tracks almost the full length of the PCB carrying a reasonable amount of current which wouldn't be a good idea really.Quote
07-03-2014, 17:18:40
Conchubair
That you reached a firmware limit in the overclock is interesting. I hope they will change this in a later update if its not a core restriction. IF thats the case right across the board for Maxwell cards then it could be an exciting time for GFX card overclockingQuote
