ASUS GTX780Ti DirectCU II OC Review
Sleeping Dogs
Sleeping Dogs
Three or four frames shy of the finest results isn't usually something to worry about, and we suppose it isn't here either. The DirectCU II OC is consistently a few frames behind though, which is why we're pointing it out.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
21-02-2014, 09:29:30
barnsley
I still stick by my belief that asus are becoming lazy in terms of GPUs. The 290/290x is crap as far as 290s go for example. I don't know if I have too high an expectation from asus but I was expecting more.Quote
21-02-2014, 09:35:30
tinytomlogan
I think you are, can only do as much as the core will allow. Short of making a new GPU they couldnt have done any more to try and polish the 290 & 290X
This is a great card but the stock clocks are lower than the mental fast ones we have tested and the silicone lottery was not shining in our favor with the Ti
Never the less its still cheaper than the £600+ ones that we have looked at and still a mental fast card.....Quote
21-02-2014, 09:44:08
barnsley
They could've made a cooler that wasn't the 780's one .
I'm sure if they do a platinum version it'll be amazing. I'm tempted to say that MSI have the market sector that the normal DCUII cooler used to take.Quote
21-02-2014, 10:08:43
tinytomlogan
If they made a new cooler every time the price would rocket....Quote
21-02-2014, 10:32:25
barnsley
Yeah I know this its pretty obvious that is the case however others did a better job. Surely the flagship of each generation of 'card, be it Nvidia or AMD, should have coolers designed or at least modified around the card in question. Prices would be a bit higher, but if you're getting the flagship 'card you're not going to worry about price that much. Obviously it'd be unfair to expect them to do what GPU specific brands do (e.g. Sapphire, Gainward) and come up with a cooler that performs excellently across the range of chips. I'm sure if they do some super powered 'card it'll be amazing as I said earlier its just the DCUII isn't as good as others and with Asus being huge players you'd expect more.Quote
