ASUS MS236H Monitor Review
Introduction and Specifications
Published: 6th May 2010 | Source: ASUS | Price: £211.96 |
Monitors have come a long way in recent times. For people of a certain age, and so that includes me, the thought of a monitor supporting VGA seemed to be very up-market indeed. Quickly a 14" monitor was replaced by the behemoths that were 1600x1200 CRTs, taking up swathes of desk-space, power, and weighing the best part of a ton.
The main problem with CRTs was the refresh rate issue. Although a lot of people didn't notice I always found a 60hz refresh rate gave me a monster headache, and I'm sure I'm not alone.
LCDs very quickly appeared on the market at incredibly high prices for even the tiniest monitor, so for a long while the choice for anyone needing a new display was either to buy a big, cumbersome, high resolution CRT. Or to spend much more on on a very small LCD that wasn't much use for gaming because technology hadn't caught up.
Now of course that's a distant memory. TN panels are so cheap, and LCD monitors so prevalent, that not owning a widescreen monitor around 22" is almost unheard of. So affordable are they that owning a couple is within the means of most, and both ATI and nVidia have based their latest technologies about you having three.
As the actual "wonder" of having a flat panel is so diluted as to be meaningless, manufacturers have taken to using those little details to steer you towards them.
Enter ASUS.
ASUS MS236H Technical Specifications
ASUS have gone down the design road for their MS236H, and we'll take a close look and how this works on the next few pages. For now though we'll grab the technical specifications from the ASUS website.
TFT-LCD Panel | Panel Size: 23“ Wide Screen Color Staturation 72%(NTSC) True Resolution: 1920X1080 Pixel Pitch: 0.265mm Brightness(Max): 250 cd/㎡ Contrast Ratio (Max.): 50000 :1 (ASCR) Display Color: 16.7M Viewing Angle (CR≧10): 170°(H)/160°(V) Response Time: 2 ms (Gray-to-Gray) |
| Video Features | Trace Free Technology SPLENDID Video Intelligence Technology SPLENDID Video Preset Modes (5 modes) Skin-Tone Selection (3 mode) HDCP support Color Temperature Selection(5 modes) |
| Convenient Hotkey | SPLENDID Video Preset Mode Selection Auto. Adjustment Brightness Adjustment Contrast Adjustment Input Selection |
| Input / Output | PC Input: HDMI/D-Sub Video Input: HDMI 1.3 AV Audio Input: HDMI 1.3 Earphone jack: 3.5mm Mini-jack (for HDMI only) |
| Signal Frequency | Analog Signal Frequency: 30~85 KHz(H)/ 55~75 Hz(V) Digital Signal Frequency: 30~85 KHz(H)/ 55~75 Hz(V) |
| Power Consumption | Power Consumption < 33 W Power Saving Mode < 1 W |
| Mechanical Design | Chassis Colors: Black/White Tilt: +10°~+20° |
| Security | Kensington lock |
| Dimension (WxHxD mm) | Phys.Dimension(WxHxD): 566.2x406.8x150.9mm Box Dimension(WxHxD): 640x510x145mm |
| Weight | Net Weight (Esti.): 3.9 kg Gross Weight (Esti.): 6.2 kg |
| Accessory | VGA cable Power cord Power adapter Quick start guide HDMI-to-DVI cable warranty card |
Not much there of outstanding note. The specifications are round about what we'd expect for a TN panel.
While I'm sure many will appreciate the aesthetics of the Monitor, I personally feel that the poor stand and missing VESA mount alone make it a deal breaker. Also consider that at £210, this monitor is among the most expensive TN panels, of which many are LED backlit. Perhaps I'm spoilt by my 2408WFP's viewing angles but even for a TN panel, it doesn't look great at all. I suppose I can't judge the monitor without seeing it in person but I'm not certain that it's thin and minimalistic design offsets its shortcomings.
I had the same boxing on my tv when i was using hdmi with my old 4850's, somewere in CCC there is a slider that you just have to slide across and it fills it up to full screen (not that i can remember what its called).
Continue Reading
