ASUS nVidia GTX590 Review
ASUS GTX590 Review
Putting two GPUs onto a single circuit board is a fairly recent trend for the highest models in a particular graphics card series. Although it had been tested before with varying success it was the GTX295 and ATI HD4870X2 that really proved it was both possible and beneficial to go for SLI/Crossfire but on a single card.
Of course the primary benefit is that you can buy two, and go for a Quad-GPU setup, but there are also energy savings over having two single cards.
Heat however is the largest hurdle to overcome. This has been dealt with either by reducing the performance of the GPUs used, or resorting to something that sounds like a 747 taking off.
Today we're looking at the latest attempt from nVidia, the GTX590. It comes at the perfect time as we've only just reviewed the AMD HD6990 and so we can really get to grips with which of the two is the King of single card performance.
Without further ado let's get to it.
Product Name
GeForce® GTX 590
GPU
Dual NVIDIA® GeForce® GTX 500 series
Engine Clock speed
607 MHz
Unified Shaders
1024 (512 per GPU)
Shader Clock
1215 MHz
Memory Clock speed
3414 MHz
Memory
3072MB DDR5 (1536MB per GPU)
Memory interface
768-bit (384-bit per GPU)
Display Outputs
Triple DL-DVI-I, mini-DP
HDCP
Yes
Cooling
Active (with fan) (dual-slot)
DirectX® version
DirectX® 11 with Shader Model 5.0
Other hardware features
8-channel Digital Surround Sound, HDMI 1.4a compatible, HD Audio bitstream capable, hardware accelerated Blu-ray 3D ready, Quad NVIDIA® SLI™ ready, NVIDIA 3D Vision™ Surround ready
Software Features
nView® Multi-Display, Hardware Video Decode Acceleration Technology, NVIDIA® CUDA technology, OpenGL® 4.1,
Windows 7 capability
Windows® 7 with DirectCompute support
«Prev 1 2 3 4 5 6 7 8 Next»
24-03-2011, 09:00:42
sources95
sweet mother of jesus!Quote
24-03-2011, 09:05:30
MR J DAWG
that thing is BEAST!!!!Quote
24-03-2011, 09:05:49
Zeals
Wow they really turned down the GPUs in this thing.Quote
24-03-2011, 09:06:54
sources95
Just imagine that thing with a waterblock...Quote
24-03-2011, 09:09:52
tinytomlogan
Ill post the [email protected] stats here in a bit but basically 6800 WU's were 13k on each core. All the details are in the video though. (had to go careful with uploading too early on this one but the vid will be up asap)Quote
