Club 3D 7870 Joker XT Edition Review
Club 3D HD7870XT Joker Edition Review
The current selection of midrange Radeon cards provide some of the best value for money around in any hardware category. Not only are they good value but they perform excellent and, even better for us, they overclock well too. Club 3D are fairly new to our shores but both the HD7850 and HD7950 that we've reviewed have blown our socks off, and led to them taking home two of our Best of 2012 awards.
Today we're taking a look at the latest iteration of the HD7870, here in XT trim which comes with 256 additional stream processors when compared to the original HD7870 GPU.
Does the award-winning roll that Club 3D are on continue, or is this truly the joker in the pack?
It's not just the stream processor count that's been jacked up on the HD7870XT. Whereas the original HD7870 came on the Pitcairn GPU, the XT utilises a Tahiti LE GPU. This is a slightly cut-down version of the one found on the HD7950. So although it has the HD7870 name, it's actually got far more in common with a HD7950, except for a reduction in stream processors and less GDDR5 memory. We know that seems as clear as mud, so let's just get it on the bench rig and see how it performs.
Model
Product Name: Radeon HD 7870XT jokerCard
Product Series: Radeon HD 7000
Item Code: CGAX-7876XT
EAN Code: 8717249411437
Interface
Bus Interface: PCI Express 3.0
Chipset
GPU Chipset: Tahiti LE
GPU Clock: 925 MHz
GPU Boost Clock: 975 MHz
Stream Processors: 1536
Multi-GPU
Multi-GPU: Dual CrossFire Ready
Memory
Memory Size: 2048MB
Memory Interface: 256 BIT
Memory Type: GDDR5
Memory Clock: 6000 MHz
Cooling
Cooling Type: Active Fansink, CoolStream High Performance Cooling Technology
TDP
Idle: 30W
Idle ZCP mode enabled: 3W
Maximum load: < 210W
3D API
DirectX version: 11.1
OpenGL version: 4.2
OpenCL version: 1.2
Dimensions
Slot Width: 2 Slots
Profile: Standard profile
Card Size: 268x122x36mm
Weight
Card Weight: 672g
Output Configuration
DVI: 1x Dual-Link DVI-I
HDMI: 1x version 1.4a
Mini DisplayPort: 2x version 1.2
HDCP ready: YES
RAMDAC: 400MHz
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
14-01-2013, 03:19:50
tinytomlogan
Hot on the heels of their success in the OC3D Best of 2012 awards, we take a look at an XT variant of the HD7870 from Club 3D.
http://www.overclock3d.net/gfx/artic...112856620l.JPG
Continue ReadingQuote
14-01-2013, 03:44:46
airdeano
finally a black PCB..
man this Club 3D is churnin' out some interesting feature cards..
thanks, Tom.Quote
14-01-2013, 04:06:34
CEUOTC
Awesome card and great review TTL dude.Quote
14-01-2013, 05:05:31
dragoonk
Quite some impressive numbers there for a card in that price range, and a black PCB at last. Someone has been listening.Quote
14-01-2013, 05:19:31
Master&Puppet
These Tahiti LE cards are really exciting although I understand that there aren't going to be a lot, if any, of Tahiti LE releases from other manufacturers. It is intended to be a limited edition so get one as soon as you can...they might not be around for that long.
The TUL corporation are a major source for these releases (and TUL either owns or contracts supplies to Club3D, Powercolor and VTX3D). I'm only aware of Sapphire being the other manufacturer to release a Tahiti LE; possibly because of other major manufacturers not wanting to compromise on the existing 7870/7950 price point given the amount of stock they will likely have.
Cards to look out for:
Club3D Joker
Powercolor 7870 Myst
VTX3D 7870 Black
Sapphire 7870 XT
There is also not going to be an AMD reference Tahiti LE. Also worth noting that this will not crossfire with other 7800 "Pitcairn" cards but will work with 7900 cards which obviously have the same "Tahiti" PCB.Quote
14-01-2013, 05:22:58
Koolzy
This reviewed version of the 7870 is a great value. With a nice look and with benchmarks that are better than any other 7870, also with some interesting results compared with other gpu. All of this makes this a great choice for any one that wants a good product vs cash. Nice review Tom.Quote
14-01-2013, 07:02:50
S.T.A.L.K.E.R
Very nice review..This card is very good.I dont know for you guys,but i was always like more NVidia..I know that Ati is faster,but that PhysX from Nvidia are incredible..thanx for great reviewQuote
14-01-2013, 07:25:14
jamed2017
Looks like a little beast of a card.Quote
14-01-2013, 07:27:39
FTLN
Another top review, the time is coming for me to get a new system....
Do you think were gonna see anything from nvidia to counter this card, like a 660 with more shaders unlocked ???Quote
14-01-2013, 08:35:06
xMBliss
Great review as allways. Was expecting to see a bigger boost in frame rates when overclocked, still a beast of a card for its price.Quote
14-01-2013, 08:42:36
dampchimp
Really interested in this card, just wondered (if I can ask here), where you can get it for this price and with the free games?Quote
14-01-2013, 10:16:53
badtaylorx
just to clarify....is this performance duplicated on ALL tahiti le cards, or just the joker???Quote
14-01-2013, 11:23:00
Nerdfighter
All Tahiti LE cards have the same core clock and memory clock, so at stock, the answer would be yes. Though I can't vouch for the Sapphire one, because as far as I understand, it hasn't gotten more processing units, but has a higher clock or something in those lines.
What I'm curious about is if the 3 Tahiti LE cards available in Europe: PowerColor 7870 Myst. Edition, VTX3D 7870 Black Edition and Club3D 7870 jokercard have the same cooler and PCB? The Club3D one is around 20 - 25€ more expensive, I don't really understand why.Quote
14-01-2013, 11:44:47
JiggaHertz
Really impressed by Club3Ds cards based along the 'cards' theme. Ace, King, Queen, Joker etc.Quote
14-01-2013, 12:22:31
greybeard
tend to agree xmbliss i overclocked a 6870 with gelid icy rev2 cooling to 925 mhz i got 62 fps avg on the heaven benchmark just tried it out for funQuote
14-01-2013, 12:36:30
Maestro_P
hmm, seems Club3d is trying to get a better image among overclockers. I myself have never been a fan of the brand. Only seen ones that went bad even on stock settings. But that was with an old fx5700 so they could've come a long way since then. Really hope they get competetive with other brands, helps drop the prices Quote
14-01-2013, 12:50:54
J-a-c-o-b
Found this on Amazon I hope, can someone confirm (preferably Tom) that this is the right one.
http://www.amazon.co.uk/Club-3D-HD78...8185753&sr=1-2Quote
14-01-2013, 12:55:43
xMBliss
yeah the joker one is taihiti le. besides it says it has 1536 stream processors, regular 7870 has 1280.Quote
14-01-2013, 13:12:08
Hails13
It would appear the club 3d seem to be producing some good cards and the black pcb is definatly a bonus, will have to see how much money i have soon but the 5770 could do with an upgrade i thinkQuote
14-01-2013, 13:17:21
J-a-c-o-b
Shweet, saved to favouritesQuote
14-01-2013, 13:36:49
Soda-88
It's been so long since I've seen Club3D cards... I actually had their Ati Radeon 9600XT paired up with AMD Athlon XP 2500+ (Barton; OCed to 3200+), it was amazing for what it costed me. Good to see them doing well with 7000 series Quote
14-01-2013, 14:02:50
Dorkstar
Club3d has really made some impressive products since i've been following them over the past few months. Shame they aren't in the US yet.Quote
14-01-2013, 14:43:25
Martynas
Really nice card from amd & club3d.Quote
14-01-2013, 15:08:47
kharma45
And someone I know just bought a 660 a few days ago, ah well.Quote
14-01-2013, 22:43:10
Mgutierrez33
True freakin story... I would love to get my hands on one o these cards for my Troll build I'm working on, but it seems the only tahiti LE card I can find stateside (atm) is the PowerColor branded card, and the heatsink on that one looks questionable at best. reviews peg the temps as being appropriately high as well .
Also, anyone got any ideas as to water block compatibility with this card? Kind of an oddball, so I would suspect that one doesn't exist (unless you get a GPU-only block)Quote
15-01-2013, 05:04:18
Master&Puppet
You can also tell by the XT at the end of 7870XT. That's how most companies will be listing them.
Limited edition non-reference cards - I very much doubt anyone will be making waterblocks for these I'm afraid. I've checked cooling configurator and EK have no plans to make one for any of the 7870XTs.Quote
15-01-2013, 05:43:48
iBeInspire
Would be a lovely upgrade for my aging 6850... Don't really have the money for anything other than crossfre now though x.xQuote
15-01-2013, 07:03:12
yassarikhan786
Really fantastic card for the price and awesome review as alwaysQuote
15-01-2013, 10:35:32
powerfuse0
Did you order one of those? I would like to know what you got, if you got?
Because i'm looking at getting one of these pretty soon, and they're out of stock on the Kuston PC site that is linked in the review.Quote
16-01-2013, 17:36:29
RizeAllard
It seems to be a real joker in this price! I hope it will be on shelves here too.Quote
16-01-2013, 20:32:56
golemka
i want this card with that pedobear instead of my 5770 ... Quote
17-01-2013, 09:55:38
powerfuse0
just ordered mine Quote
11-02-2013, 14:02:45
Geee-master
Got mine and it's just awesome so worth the wait. Bought of amazon got it 3 weeks later. Truly epic card for the moneyQuote
11-02-2013, 14:07:21
powerfuse0
I got mine a couple of days after I ordered it. Got it from the site TTL said about. Kustom PC or something, Do you find that the fan it loud on 60%? & also does auto fan speeds make the card get too hot?Quote
11-02-2013, 15:45:47
Geee-master
Mine clocked at 1150 on the GPU and 1550 on the ram it is quite loud but not as bad as my old xfx 5870 that was way louder than the 7870 on 60% manual fan speed. The cooler is brilliant 32 degrees on idleQuote
09-03-2013, 19:24:41
Rich_
would like to see how more 7950's scale on the 3dmark11 graphQuote
