Gigabyte GTX750Ti Windforce Review
So far we've looked at a handful of GTX750Ti's and found them all to be extremely close in performance. Such is the consistency of the nVidia GPU manufacturing that it's hard to buy a bad one.
That does mean that the same applies at the other end of the scale, and so it is on very fine margins that decisions between particular brands and models of GTX750Ti are made.
With the Gigabyte Windforce version in our sweaty hands we find out if this has enough to offer to bring it above the throng. After all it's from a very reputable manufacturer and, as we'll see on the next page, has enough cooling capacity to keep a far more powerful card feeling frosty.
ChipsetGeForce GTX 750Ti
Memory Clock5400 MHz
Process Technology28 nm
Memory Size2048MB
Memory Bus128 bit
Core ClockBase:1033MHz Boost:1111MHz (Standard- Base:1020MHz Boost:1085MHz)
Card BusPCI-E 3.0
Memory TypeGDDR5
DirectX11.2
OpenGL4.4
PCB FormATX
Digital max resolution4096 X 2160(via 2 HDMI)
Analog max resolution2048 x 1536
Multi-view4
I/ODual-link DVI-I*1/DVI-D*1/HDMI*2
Card sizeL=204mm , W=144 mm,  H=42mm
Power requirement400W
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 Next»
23-05-2014, 06:28:31
tinytomlogan
http://www.overclock3d.net/gfx/artic...105336566l.jpg
Today we return to the GTX750Ti, with the Gigabyte Windforce version. How does it stack up?
Continue ReadingQuote
24-05-2014, 17:42:47
metalgun2000
After all this time I thought Gigabyte was done with the blue PCB. Poor form. Excellent card for the money though.Quote
