MSI GTX780 Gaming Review
Sometimes a product arrives at our offices that we can't imagine not liking. Every box is ticked. Of course that doesn't mean that we'll be as pleased by the end of our time with it, but initial impressions are good. So what makes this something that had our root fizzing?
For a start it's a GTX780, easily the best graphics card around right now. Sure a GTX Titan might just have the edge in particular scenarios, but in terms of mind-blowing performance at a reasonable price the GTX780 is our recommendation for anyone looking to upgrade from anything below a GTX690. It's that good.
Secondly it's equipped with the MSI Twin Frozr cooler. One of our favourite coolers, it's been found on everything from GTX460's to HD7970s, and always does the job while looking cool. Speaking of looking cool, as part of the MSI Gaming range is has the Dragon logo and accoutrements. It also should combine with a Gaming range motherboard, to enable one click overclocking for the whole system. It also, if the mood strikes, allows for one click silent mode. Handy if you're watching a film and want to detune your entire system for silence. At the time of review the software to enable this is still being tweaked by MSI and so isn't part of our test today, but it's worth noting if you want a simple holistic adjustment free from the faff of adjusting your whole system separately.
As we'd expect from a factory overclocked graphics card, the MSI Gaming has a serious boost to both the regular core speed and the Boost speed. Hopefully there is some performance left for us to extract.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Next»
26-07-2013, 07:25:20
tinytomlogan
Today we review the MSI GTX780 Twin Frozr Gaming, a card that perfectly matches their Gaming range of motherboards. Is it any good?
http://www.overclock3d.net/gfx/artic...091148103l.JPG
Continue ReadingQuote
26-07-2013, 07:39:46
SieB
Yep, the Titan sure is worth that extra £300
Awesome card from MSI as usual, if this is what the normal OC version performs like I can't wait to see the lightning.Quote
26-07-2013, 08:39:29
antihero
It would be impossible not to recommend it as it's the best GTX780 around at the moment.
Performance-wise, this isn't the best 780 at the moment. The Classified scored 1891 points higher in FireStrike when overclocked on air. EVGA claims it was a retail card. However, it still might have been cherry-picked.Quote
26-07-2013, 11:23:47
SHAD3Z
I'd still stick with a windforce any day. But if I were to get an MSI Gaming Board I would definitely get one or two of these!Quote
26-07-2013, 11:35:41
NeverBackDown
For reviews i always assume cherry picked cards. Nonetheless great reviewQuote
26-07-2013, 12:59:16
tinytomlogan
That we have tested doofus. If you want to listen to manu's then why read our reviews.Quote
26-07-2013, 13:03:48
Spiderz
Still not a massive fan of the styling of the Msi gaming gear but you can't exactly argue with the performance of them. Another good review TTLQuote
26-07-2013, 17:26:28
GoogalyMoogaly
I'm sure my post in this thread got removed. Not sure why.
I'm sure Tom said EVGA always use reference coolers and I linked to an EVGA ACX card. Not quite sure why that post needed removing (and Tom's post was edited to remove the comment).
Did I miss a forum rule regarding pointing out mistakes? (I maybe could've done it less sarcastically, but was trying to be helpful)Quote
26-07-2013, 17:45:45
antihero
I always seem to break the "don't correct Tom on anything or give feedback" rule whenever I point something out that I actually read in the review.Quote
26-07-2013, 19:44:42
NeverBackDown
Guys this is a review page. Please leave it posts related to the review. Customers are more apt to not come back to the website if people are arguing in the comment section below a review. Please keep it postitive, thanksQuote
27-07-2013, 02:37:07
kittysniper
Great card extremely good value compared to gtx titan, but im just not sure about the price compared to 7970, you can buy 2 7970 with that price tag(granted amd has xfire driver issue), hopefully amd will put out new drivers along with 8970 cards so I can steal a pair of these cheaplyQuote
27-07-2013, 12:47:43
NeverBackDown
The drivers that fix the problem are already out and have fixed it to an extent. New ones should come out by end of this month. But i would still take a 780 over 2 7970s just for resale value and i can always sli the 780 later.Quote
27-07-2013, 14:39:28
MiNo
I'm looking for a 780 with aftermarket cooler (for the nice OC) but I'm not willing to dump 250 watt inside the case. With the vertical cooling fins, perhaps this card actually manages to dump some heat outside.
Will the testers venture a estimate on how much heat goes outside?Quote
27-07-2013, 15:56:16
Vlada011
I will start to bite soon if friends not came from USA soon with my 780.
Because they need to back on work and I think last date is about 20 Avgust.
I will crazy completely but I 'm happy always when I buy exactly model I want.
Some 780, or some 780 with good cooling for me is nothing.
Other models are close to me but not interesting at all.Quote
29-07-2013, 13:55:38
Kaapstad
I will find out next month when the lightning hits the shelves, I will be getting a pair of lightnings and overvolting them. Then I will see how they go against the Titans.Quote
29-07-2013, 14:12:51
AverageNinja
This card looks neat! Thanks for posting Tom!Quote
22-08-2013, 10:15:38
Ya93sin
Looks good, those Twin Frozr coolers are very effective.
I wish they put the power cable socket on the short side of the card though, I think it would help for the cable management Quote
10-10-2013, 08:04:52
murphy7801
Does anyone know if this is a reference PCB or not?Quote
10-10-2013, 08:16:32
tinytomlogan
Yes matey it is, the only ones they do that are not are the LightningsQuote
10-10-2013, 12:38:57
murphy7801
Thank you . Though still tempted by a couple of lightings but waterblocks from EK seem to be taking an age.Quote
