MSI N280GTX OC HydroGen
Test Setup
To ensure that all reviews on Overclock3D are fair, consistent and unbiased, a standard set of hardware and software is used whenever possible during the comparative testing of two or more products. The configurations used in this review can be seen below:
CPU: Intel Nehalem i7 920 Skt1366 2.66GHz
Motherboard: Asus P6T Deluxe ‘OC Palm’
Memory: 3x2GB Corsair Dominator DDR3 1600mhz @ 8-8-8-24
HD : Hitachi Deskstar 7k160 7200rpm 80GB
GPU: MSI NGTX280 OC HydroGen
Graphics Drivers: GeForce 181.4
PSU: Gigabyte ODIN 1200w
Radiator: Thermochill PA120.3 (3xYL DSL-12)
Pump: Laing DDC18w (XSPC top 1/2″)
During the testing of the setups above, special care was taken to ensure that the BIOS settings used matched whenever possible. A fresh install of Windows Vista was also used before the benchmarking began, with a full defrag of the hard drive once all the drivers and software were installed, preventing any possible performance issues due to leftover drivers from the previous motherboard installations. For the 3DMark and gaming tests a single card configuration was used.
To guarantee a broad range of results, the following benchmark utilities were used:
⢠3DMark 05
⢠3DMark 06
⢠3DMark Vantage
3D Games
⢠Crysis
⢠Far Cry 2
⢠Company of Heroes
⢠Race drive: GRID
⢠Call of Duty IV
⢠Unreal Tournament III
Power Consumption
Power consumption was measured at the socket using a plug-in mains power and energy monitor. Because of this the readings below are of the total system, not just the GPU. Idle readings were taken after 5 minutes in Windows. Load readings were taken during a run of Crysis.
Temperatures
Temperatures were taken at the factory clocked speed during idle in Windows and after 10 minutes of running Furmark with settings maxed out (2560×1600 8xMSAA). Ambient temperatures were taken with a household thermometer. As we use an open test bench setup consideration should be given to the fact that the temperatures would likely increase further in a closed case environment.
Â
For our overclocking tests I used Rivatuner to overclock the card which is perhaps the most commonly used generic utility to overclock GPU’s at a driver level. To test stability, I ran 3D Mark 06 and a few runs of Crysisbench which I confess does not signify true 24/7 stability, however, it does give a good indication of stability nonetheless as heat would be the main enemy. As you can see above, this is not the case with this graphics card.
We left the shaders linked to the corespeed which also reached an astonishing 1584Mhz. Couple this with a memory overclock of a further 200mhz past the 1150mhz overclock as standard, and this is by far the fastest GTX we have ever come across. Simply amazing.
Let’s move on to our suite of benchmarks where we pitch it up against the ATI 4850×2, GTX285 and stock GTX280…
