nVidia GTX780 Ti Review
Test Setup, Overclocking and Temps
nVidia GTX780Ti Review
Test Setup
nVidia GTX780Ti
Intel Core i7-3960X @ 4.6GHz
ASUS Rampage IV Extreme
Corsair Dominator Platinum
Corsair AX1200i
Corsair Neutron GTX
Corsair H100i
Windows 7 x64
Overclocking
As we'll see on the next page there are some under the hood tweaks that allow the GTX780Ti to overclock better than its predecessor. Rather than draw all the power from either the PCI Express 3.0 slot, or the power inputs, the GTX780Ti manages the balance between them better. This has an enormous benefit to the overclocking with incredible speed attainable. The GPU Core is bumped from 876MHz to 1101MHz thats a 225MHz offset and the the boost pushes this even further up to an amazing 1244MHz! The already blisteringly quick 7GHz GDDR5 manages a further 600MHz, which should make a big difference in our high resolution tests.
Temperatures
As both AMD and nVidia now use any thermal headroom to increase the performance of their card, so the temperature testing is less about the cooler than it used to be. However, it's clear that the reference nVidia cooler is a much better proposition for the rest of your system when compared to the Radeon. That heat has to go somewhere and with the GTX780Ti there is less of it to disperse.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
07-11-2013, 09:28:40
s13viper
Very nice, super speed, but far too expensive. In australia they will be $850+. Ill get 2! 290's and put them under water for $1000. Much faster, looks better, quieter and less heat for not much more money. An easy choice. I was waiting until the 290x/290 and 780ti came out to decide and now the choice is easy. For anyone on water you would be crazy to pay $850 for one of these when a 290x on water is just as fast, quieter and cheaper for $250 less.
For those not on water the choice is much harder for sure! For single GPU a 780ti makes sense, but dual 290's on stock fan profiles are a serious contender.Quote
07-11-2013, 09:32:27
MrKambo
Cheers mate!
it truly is an amazing card, and for anyone wanting to spend that kind of money for whatever reason its awesome!!
haven't watched the video yet, but ill save that for later, from what ive read, its not worth getting rid of my 780 classy for this, as my classy overclocks quite well, and isnt far off the FPS the Ti produces!Quote
07-11-2013, 09:41:17
SieB
I'll take 2 please, Bob Lol, I wish.
I want to see what can be done with this card with overvolting! If it overclocks that well by just upping the power limit slider, then upping the volts must give even better results.
I do feel sorry for all the people that bought the Titan though, everything from the 780, 290/x and now the 780 Ti is just a slap in the face to the people that spent £800 on it.Quote
07-11-2013, 09:44:32
ShaunB-91
I guess those who have the Titan have deep pockets though so they won't be bothered. Has anybody on this forum got a Titan? I don't think there is..?Quote
07-11-2013, 09:45:29
tinytomlogan
I do. Its in the box Quote
