Palit GTX780 Ti Jetstream Review
Palit GTX780Ti Jetstream Review
The GTX780Ti wowed us with its outstanding performance. We weren't sure that there was much more to be squeezed from the Kepler GK110 core, and yet the nVidia GTX780Ti managed to make the regular GTX780 seem fairly pedestrian in comparison.
As fantastic as the GTX780Ti is in regular trim, the abilities of the GPU Boost 2.0 to overclock your card depends largely upon the thermal headroom available and so putting on a non-reference cooler should potentially unlock even more performance.
Thanks to the fine folks at Palit we can find out as today we're reviewing their Jetstream-cooler equipped variant on the GTX780Ti.
Out of the box the Jetstream appears to be a fairly standard GTX780Ti, if standard is a word that could be used for it. The clock speeds are the usual 980/1046/7000MHz that we've come to expect. So let's move on to the Jetstream cooler itself and see what that has to offer.
Memory Amount3072MB
Memory Interface384bit
Graphics Clock (MHz)Base Clock 980MHz/Boost Clock 1046MHz
Memory Clock (MHz)3500MHz (DDR 7000MHz)
CUDA Cores2880
Memory Bandwidth (GB/sec)336
NVIDIA SLI-ready2-way
Microsoft DirectX11
Bus SupportPCI-E 3.0 x 16
Certified for Microsoft Windows 7Y
Certified for Microsoft Windows 8Y
Maximum Digital Resolution4096x2160
Maximum VGA Resolution2048x1536
Dual-Link DVIYes x2
Height2.5 Slot
Board Length280mm
PCB Width267mm x 112mm
Graphics Card Power (W)250 W
Minimum Recommended System Power (W)600 W
Supplementary Power Connectors6-pin X1 8-pin X1
AccessoryManual, Driver Disc, Power Cable
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Next»
06-12-2013, 05:50:26
Our first GTX780Ti with a non-reference cooler comes from Palit. Does this extra cooling unleash even more performance?
Continue ReadingQuote
06-12-2013, 07:33:15
You may need a 4K-Res. Display for the next Generation of Graphics Cards to see if they can handle the next step of evolution ;-) ^^ :-DQuote
06-12-2013, 07:47:55
Thats a way off in our eyes both for us and the consumer mateyQuote
