PowerColor HD6990 LCS Review
AvP and Black Ops
Published: 17th July 2011 | Source: PowerColor | Price: £619 |
Alien vs Predator
When it comes to Giger inspired slaughter there is a new King on the block. The PowerColor is a full 8FPS ahead of the GTX580 SLI and 20 FPS ahead of the stock HD6990.
Call of Duty - Black Ops
If you're a fan of the Infinity Ward shooter then you have nothing to worry about here, or to be honest with any card. It's a surprise to see the LCS behind the stock HD6990 though. Albeit only a couple of frames.
(Results in the oc3d reviews are still troubling me, especially when you look at same cards with better settings, where, to be fair, they really can't be slower.)
Ultra damn fast fps for sure. No quality and physx for me tho.
I actually thought it would be more expensive.
Personally I think any card that comes with a waterblock by default should have some sort of voltage tweaking so you can better exploit the extra cooling potential.
Also on the side note:
If you're a fan of the Infinity Ward shooter then you have nothing to worry about here, or to be honest with any card. WTF
Continue Reading
