Zotac GTX590 SLI 5760x1080 Nvidia Surround Review
Published: 9th June 2011 | Source: Zotac | Price: |
If you're a regular reader, and if not why not, you'll have been awaiting today's review.
After dipping our metaphorical toe in the triple-screen water with the HIS HD6990, today we're back with a nVidia offering in the form of the Zotac GTX590.
Of course we could just review a single card, but as Zotac kindly offered to lend us two so we could run in SLI we'll be testing in both forms today.
Popping along to the Zotac website we find the specifications for the GTX590. Unlike the AMD solution the nVidia multi-screen setup is based off of 3x DVI connections rather than mini display ports.
Otherwise it's a standard reference design card.
| Model | ZT-50501-10P |
| Cooler Type | Fan (Dual Slot) |
| Core Clock | 607 MHz |
| Core Processors | 1024 (2 x 512) Stream Processors |
| Dimensions | 4.376in x 11in - 111.15mm x 279.4mm |
| DirectX | DirectX 11 |
| Dual-Link DVI Supported | Yes |
| DVI | 3 |
| GPU | GeForce GTX 590 |
| HDCP Ready | Yes |
| HDMI | 1 x Mini-HDMI 1.4 |
| Interface | PCI Express 2.0 x 16 (Compatible with 1.1) |
| Max Resolution | 2560 x 1600 |
| Memory Clock | 3414 MHz |
| Memory Size | 3072MB (2 x 1536MB) |
| Memory Interface | 768-bit (2 x 384-bit) |
| Memory Type | GDDR5 |
| Recommended Power Supply Wattage | 700-Watt |
| Package Contents | 1 x DVI-to-HDMI cable 1 x DVI-to-VGA adapter 2 x Dual 6-pin PCIe to 8-pin PCIe power adapter 1 x Assassin's Creed®: Brotherhood game bundle 1 x Driver Disk 1 x ZOTAC Boost software bundle 1 x User manual |
| RAMDAC | 400 MHz |
| SLI Supported | Yes |
| Weight | 5.3500 lb |
| Warranty | 2-Year Standard Warranty; Limited Lifetime Extended Warranty |
Time to have a look at the card and bundle.
590s are dual GPU
2 are used in this sli test - cos that is the only way nvidia can run triple monitor setups
very expensive (~£1100)
HD6990 are also dual GPU
a single card is needed for triple eyefinity setups...... AND ONLY ONE WAS USED
half the price (of the nvidia counterpart) for tri-monitor (~£560)
and judging by the benchmarks - the 6990 wins (due to the forementioned)
looks great, but as usual (lol) i have my concerns... 590s are dual GPU 2 are used in this sli test - cos that is the only way nvidia can run triple monitor setups very expensive (~£1100) HD6990 are also dual GPU a single card is needed for triple eyefinity setups...... AND ONLY ONE WAS USED half the price (of the nvidia counterpart) for tri-monitor (~£560) and judging by the benchmarks - the 6990 wins (due to the forementioned) |
Might want to read the review or at least check your facts before ranting
Single 590 test was with tripple screens.... So errrrm ONLY ONE WAS USED Might want to read the review or at least check your facts before ranting |
6990CF_eyefinity vs 590SLI_surround
a dual-dual-GPU tri-monitor show-down
oh hell yeah I am
I TOLD YA SO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I've been saying all along that Nvidia was King of the Hill even if the ATI was a few fps better in benches back when first released the noise/heat ration between the two made Green Team the clear winner. Now since drivers for both have been fixed Green is ahead in all aspects. I'm not going to say it........ lol XD +1 for that piece of awesome. Good lord tho man, if the 590 just killed the 6990....does that mean the Mars II will freaken Vaporize it XD oh hell yeah I am I TOLD YA SO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Gtx 590 sli 5970*1080
Then gtx 590 5970*1080
Then another just gtx 590 (and this one is wayyy above the others in the chart, and the sli gets lower fps then the others... I'm confused is the chart labeled wrong?.......
I don't get the charts, Gtx 590 sli 5970*1080 Then gtx 590 5970*1080 Then another just gtx 590 (and this one is wayyy above the others in the chart, and the sli gets lower fps then the others... I'm confused is the chart labeled wrong?....... |
Mentioned in the review tho, you do get some crazy unexpected results sometimes, and it can be down to drivers/coding of the games. (in my opinion, I've been begging reviewers, not just on here, to look at the way they deploy windows cos it has things in it that will hamper performance on seemingly random occasions. you see it when you bench rigs.)
Anywho, over the 2 tripple screen reviews, both stables are pumping out fps that game-coders can't keep up with! It's going to leave pc-gamers demanding more quality textures, more filtering, higher resolutions and detail and better programing on a whole.
Apart from the prices, which I've always stood by the reasoning that if you can afford 3x quality monitors and 1 or 2 of these cards from either stable - £50/£100 means very little to you, your girlfriend still isn't going to speak to you for a month whichever you get. Pricing isn't that important at this end of the market - imo. You don't pose the question 6850 or 6990 ? You're in one market or the other. Imo anyway.
What it all boils down to for me, is that shelling out onzes of cash on setups including these things, both camps cover the playable-fps, the only thing that remains is the in-game quality, and to be fair AMD are on a loser from the get-go. Lower quality samples and no PhysX just as a starter. Spend big bucks and settle for less quality ? Why would you ?
Like to know how long it takes to get used to using 3 screens for gaming tho
I'm not interested in a card that sounds like a hoover and is only slightly faster as in 2-3 FPS that you wouldn't physically notice the difference, just to say that I have a faster card, silence is bliss and the 6990 ain't.
I think we need to see a review of a 6990 and a 590 running together on a BBM though, just for laughs.
I only have one concern, if for example you have SLI "issues" with a new game (e.g. Witcher 2) and have to disable one of the cores to get it to render correctly (I understand that you can do this, I've never tried in a SLI setup) how fast is the down-clocked 580 core on it's own, faster than a 570gtx?
EDIT: Just to make it clear the above is for a single 590 gtx... I'm not made of money
I don't get the charts, Gtx 590 sli 5970*1080 [Quad GPU- Triple Monitor] Then gtx 590 5970*1080 [Dual GPU- Triple Monitor] Then another just gtx 590 [Dual GPU- Single Monitor] (and this one is wayyy above the others in the chart, and the sli gets lower fps then the others... I'm confused is the chart labeled wrong?....... |
god they are good, will trade my gf for them
Good review, there is no denying the 590 is a beast and if I had the money i'd buy it over the 6990 any day. I'm not interested in a card that sounds like a hoover and is only slightly faster as in 2-3 FPS that you wouldn't physically notice the difference, just to say that I have a faster card, silence is bliss and the 6990 ain't. I think we need to see a review of a 6990 and a 590 running together on a BBM though, just for laughs. |
You can adjust the zoom of the stats to huuuooge levels...
Ati seem to spend their time fixing micro stutter and flashing issues while nvidias driver team are constantly trying to unlock more fps.
If I was spending the kind of money these go for I would want them to be giving me the best drivers for them too and with these things in mind I think my choice is clear.
For f**** sake
/afk to drool... also, need to ask the missus summit.
*Edit* The answer was NOOOOO!!!
Might sell my car and get 2 of these =] hahah
bitch'n review otherwise......great topic for the watercooler monday
Can you run the 580 SLI scores with the 275.33 WHQL Drivers you are using for the 590's in this review?
I see you got your scores from your original 580 SLI review which are using 8 month old release drivers. This would give a better comparison of 580 SLI vs a single 590.
And, do you have 6990 CF review by any chance?
Thanks!
correct me if im wrong,,, but you did do a 6990 cross-fire review did you not??? any reason for not including those stats in with this review??? bitch'n review otherwise......great topic for the watercooler monday |
the same games were not tested in all the benchmarks. there are benches for the 6990CF, but not in a multi-monitor (eyefinity) setup, to compare to the 590SLI(surround)
the 6690eyefinity benches are in the graphs in this review, but are NOT crossfire+eyefinity
I just don't get the Metro 2033 test. It says that the single 590 got 117 FPS Average in 1920x1200, almost 3 times more than a 580. In most other tests of the 590's the fps in metro has been around 45-60. Has this something to do with drivers, cuz the boost is quite significant. |
Were there any resolving suggestions to what TTL was talking about at the end of the main review for the 590's, About how you have a single stretched desktop instead of 3 separate monitors? Because i am doing a 590 setup and that would be a buzz kill if i can not get 3 separate monitors when not in gaming i might have to go to a crappy 6990 setup... >.> and then i would have to WC them which i did not want to have to figure in to my costs.. :/ any info would be great,. |
Matt
Continue Reading
