CM Storm Alcor and Mizar Mice Review
The CM Storm branch of Cooler Master was, initially, a risky proposition. A manufacturer that had built up a wealth of brand identity moving into the extremely competitive peripheral market that requires slightly different design philosophies was always going to be a chance. Perhaps that's why the CM Storm brand was created, just in case it didn't work.
However, it's fair to say that the CM Storm brand has most definitely worked, producing an array of affordable and high quality items that have found a home on an array of desktops around the world.
Today sees the release of two new mice to the CM Storm range, and both of them combine sensible design choices with good options for the consumer, and wrap it up in a very affordable package. Let's bring in CM Storm themselves to explain :
Alcor is fitted with the Avago 3090 optical sensor while Mizar utilizes the Avago 9800 laser sensor. Both sensors are tuned for gaming with high speed actions and very precise tracking. Combine this with a low weight of about 121 grams and unparalleled ergonomics both mice are perfect for gaming. The physical design and layout of both mice remain true to a classic, right-handed, and ergonomic feel while each button is intuitively placed to ensure quick setup and more comfortable long-term use.
The Laser/Optical debate is one that rages long and hard, with both camps fervently defending their preference. With the Alcor and Mizar you can have a choice whilst not compromising the design. Both mice are almost identical, although the Mizar is the slightly higher specification model in terms of customisation, and naturally a Laser sensor is capable of much higher DPI sensitivity than an optical offering.
ModelAlcorMizar
TypeOpticalLaser
SensorAvago 3090Avago 9800
DPI40008200
SwitchesOmronOmron
Other FeaturesLED Profile IndicatorLED Profile Indicator
7 Programmable Buttons
Customisation Software
«Prev 1 2 3 4 5 Next»
24-02-2014, 03:59:58
tinytomlogan
http://www.overclock3d.net/gfx/artic...094158506l.JPG
CM Storm have been producing quality peripherals for some time now, and today we take a look at two new gaming mice.
Continue ReadingQuote
24-02-2014, 04:45:16
barnsley
the mizar is a re badge of my mouse, a Tecknet x9800 right down to the software that came with it. a couple of slight changes with the button layout on the extra onesQuote
24-02-2014, 04:58:05
SieB
The Alcor has the same sensor and switches as my Steelseries Rival.
The Avago 3090 has no built in acceleration or angle snapping whatsoever, I was using a Razer Imperator before my Rival and the sensor in that had hardware angle snapping. So even if you disabled it on the software side it was still there.
Going from that to the Avago 3090 on my Rival I could instantly tell the difference.
The CM Alcor is definitely the mouse to get if you want zero acceleration and angle snapping both software and hardware wise.Quote
