CM Storm Alcor and Mizar Mice Review
Alcor
The Alcor is almost identical to the Mizar in ergonomic terms. A right-handed mouse it follows proven design ideas with soft curves and well placed buttons giving a familiar feel.
It would be too much to describe the Alcor as squat, but it is compact with a reasonable hump to fit snugly into your palm. As a right-handed offering the right hand side is devoid of buttons but the front and back buttons on the left are well placed and you easily find them under your thumb.
The cable is plain coated plastic number with a gold-plated USB connector. It’s amusing that gold-plating has become such a normal part of an input device that it’s not even mentioned in the literature these days, whereas when it first appeared it was considered the killer feature.
