CM Storm Reaper Gaming Mouse Review
The final item in our look at three uniformly designed CM Storm products, the Aluminium range, is the Reaper Gaming Mouse.
So far we've discovered incredible build quality from the Mech Keyboard, and solid if unspectacular performance from the Pulse-R headset.
The Reaper Mouse has a lot more to live up to than the previous two reviews though. After all, the Mech keyboard was following some more mid-range models, and the CM Storm history with headsets has never been their star item. Mice, however, most certainly are the product that has consistently produced the goods.
Whether it's the Recon, Havoc, Sentinel or Xornet, the back catalogue of CM Storm mice is a parade of excellent products at great prices, and we've loved every one. Time to discover if the latest addition to this suite of mice hits it out the park.
If you're a connoisseur of gaming rodents you'll know that the main two parts of the Reaper are already spot on, with the outstanding Avago 9800 sensor married to the glorious Omron switches. In the same way that any mechanical keyboard worth its salt uses Cherry switches, so all the top end mice tend to use the Avago/Omron combination.
DesignPalm Design
BodyPlastic / Aluminum / Rubber
SensorAvago 9800
DPI8200
SwitchOmron 5 million clicks
Onboard Memory128k
Inch Per Second150
Max. Acceleration30g
LED colorWhite
Cable length1.8m/ 5.75 feet Braided cable
«Prev 1 2 3 4 Next»
04-10-2013, 06:54:40
dynastes
Nice mouse, stylingwise at least.
Sadly though, ADNS-9800 is not as good as most customers think and most reviewers constantly make it out to be.
No optical sensor (and lasers are optical sensors, too, although common speech mostly suggests otherwise) responses completely linearly. ADNS-9800 deviates more from the optimum than ADNS-3090 with LED illumination, to a point, where it becomes perceptible to at least some users. It is being noticed as positive acceleration, which cannot be disabled either, since it is inherent to the hardware itself.
While this is a rather small issue, which will be overlooked by most and might be acceptable to others (although I do not consider it acceptable that there never was any attempt to remove it), it is not the sensor's only flaw.
In order to achieve stabile tracking up to the ridiculous dpi range of 8200, another algorithm is applied, to "smoothen" or "stabilize" (in absence of a better term) the cursor movement. This prevents the movement to become "jittery", which could be made visible via MS Paint and would cause erratic movement.
As it is being calculated via MCU, which happens after the physical movement data have been picked up by the sensor, this algorithm delays the process of transcription into cursor movement.
This delay also is noticeable for many users, which is why most companies provide a newer firmware version by now that is supposed to lower the levels the algorithm works on (you can look into that on Corsair's support forum for example, where in concerns users of M65 and M95)
Despite of that, it is still present - and it is still possible that some users might notice it, the cursor basically will stay a slight little bit behind the actual movement (beyond the normal value - of course, there is always system-based inputlag).
Therefore I advise everyone to thoroughly research mouse technology before buying a product using ANDS-9800. It was developed for enourmous dpi only (which basically just means a higher possible cursor speed, but still is very effective marketingwise) without putting linearity of tracking or any other aspect into account. Yes, most users won't be affected by it (or at least not notice being affected), still, if you need the extent of configurability a laser sensor offers or use the mouse at a really high sensitivity, on which LED-based optical sensors wouldn't be tracking effective anymore, I would suggest to buy a mouse with ADNS-9500. In any other case, a LED-based sensor might be the better option.
Otherwise a nicely written review, I like the style being applied by the author. Still, mouse technology is not being tested to an acceptable extent on all the internet. Hopefully this will change some day.Quote
04-10-2013, 15:51:38
Robi_G
I like the look of the CM mice, still wish they'd put a DPI indicator on them though. That said it's pretty obvious most of the time as to which setting it's on.Quote
08-10-2013, 00:54:08
Willock
Hmm, really stylish.
I have to say I like the metallic scroll-wheel, the old Microsoft Sidewinder mice had them and I just cant get used to the rubbery one on my Logitech.Quote
