CM Storm Xornet Review
Up Close
The Xornet comes in a standard Mouse box, which has a Velcro flap on the front allowing you to view the mouse up close as well as get a rough feel for in beneath the plastic. Packaging design is very ‘CM Storm’ with the dominant colours being black, white and red, and the red slashes leave you in no doubt as to the company involved.
Because the Xornet doesn’t have any software the box contents are exactly all they need to be, the mouse itself and a small booklet to cover the main points.
The Xornet is a lovely blend of textures. Plastic is the majority of the mouse for cost reasons, but the places that require a lot of grip and accuracy are coated in rubber. The placement of the back and forward buttons is near perfect, with them being in very easy reach of your thumb when holding the Xornet.
Although it’s very compact, the Xornet doesn’t feel small even in my large hands. Designed for those who prefer a claw grip to the palm or fingertip methods, there is a nice ring-finger rest on the right hand side to aid comfort, as well as allow the branding decal.
Behind the scroll wheel are two buttons that allow you to switch between the various DPI presets. These are large enough to be found in a hurry if required, but placed well enough that you wont accidentally find yourself attempting to turn on a sixpence at 500DPI.
