Avexir MPOWER 2400MHz 8GB Review
Test Setup and Timings
Published: 15th February 2013 | Source: Avexir | Price: £69.95 |
Test Setup
8GB Avexir MPOWER Core Series 2400MHz RAM
Intel Core-i7 3770K @ 4GHz
ASUS P8Z77-V
Thermalright Silver Arror
MSI HD7950
Corsair F80 SSD
Cougar CM1000
Windows 7 64 Bit
Timings
Despite being rated at CAS10, the XMP profile for the Avexir set it to 11-14-14-30-2T. Worth noting if you're a "fire and forget" type of user. Manually set the timings and the kit works without a hitch.
The blue LEDs are just a little too light - though I'm sure that wouldn't be too hard to amend with a bit of masking.
I would imagine that this all costs a pretty penny however, as this is all done DIRECT through Avexir and shipped DIRECT from Avexir... WERTH IT!
http://www.avexir.com/customize/customize.html
http://www.overclock3d.net/gfx/artic...093918499l.jpg
Continue Reading
