G.Skill Trident X 2400MHz 8GB Review
G.Skill Trident X 2400MHz 8GB Kit
How quickly things change in the Memory world. Considering that beneath the many heatspreader designs we generally find the same chips, and now 8GB is pretty standard we're not seeing any large changes in capacity, you'd be forgiven for thinking that one kit is identical to another.
To a certain extent this is true. Even power-hungry users will struggle to differentiate between a 2133MHz kit at CAS9 and one at CAS10. The average man-on-the-street will have a hard time telling between a 1600MHz kit and a 2133MHz one in normal usage. Once you pass a certain threshold, usually 4GB capacity, the rest of the gains are mainly to be found in benchmarks.
That doesn't mean that we're not all eagerly anticipating the potential gains from the latest Z77 chipsets, with their native ability to run 2400MHz+ kits. After all, with pricing so competitive, why wouldn't you go for the fastest kit you can get?
Enter G.Skill, with their Trident X 2400MHz CAS10 8GB kit. We're big fans of G.Skill here at OC3D. Along with Kingston, Corsair and Crucial they're one of the big four memory suppliers, giving high performing sets at good price points. Does the Trident X continue this theme, or is the gap between 2133MHz and 2400MHz too small to justify the upgrade?
There are a few models of the Trident X in the G.Skill range. Today's test setup is the second fastest, the 2400MHz model. Of course if there is a faster one the thought occurs that these are the chips that can't run at the 2600MHz speed of the range-topper.
Model NumberF3-2400C10D-8GTX
SeriesTridentX
SystemDESKTOP
System TypeDDR3
Main BoardINTEL
M/B ChipsetZ77
Capacity8GB (4GBx2)
Multi-Channel KitDual Channel kit
Tested SpeedDDR3-2400 MHz (PC3-19200)
Tested Latency10-12-12-31 2N
Tested Voltage1.65V
Registered/UnbufferedUnbuffered
Error CheckingNon-ECC
Type240-pin DIMM
SPD Speed1600 MHz
SPD Voltage1.5V
Height54 mm / 2.13 inch
WarrantyLifetime
Fan lncludedNo
Features
Intel XMP (Extreme Memory Profile) Ready
«Prev 1 2 3 4 5 6 7 Next»
29-06-2012, 05:33:10
tinytomlogan
http://www.overclock3d.net/gfx/artic...131720465l.JPG
Today we take a look at a blazing 2400MHz kit from G.Skill. Does the extra speed pay dividends?
Continue ReadingQuote
29-06-2012, 09:51:53
AverageNinja
Awesome review! Finally an 8GB Trident X Kit Quote
29-06-2012, 10:07:36
Josh Weston
A good review once again, and I think this really hammers it home that anything more than 1600MHz is a waste, unless it's the same price as the 1600MHz DIMMs.
He says...with his overpriced 2133MHz RAM -.-Quote
